rhosimplefoam : error in solving the energy equation |
October 8, 2018, 16:17 |
#21 |
Yijiu Jiang
Rep Power: 13 |
Hi Sufjanst,
Thank you for the suggestions. I have made it work by change the BCs to the following combo p: inlet: totalPressure outlet: fixedValue U: inlet: pressureInletVelocity outlet: zeroGradient Then, I gradually increase the inlet pressure to reach the desired pressure difference. It finally gave me reasonable result. I have not really tried to use potentialFoam to initialize the field. But your suggestion of replacing sensibleInternalEnergy by sensibleEnthalpy do help me. It makes the model converge faster and more stable. Could you explain what is the reason? Thank you very much! |
April 21, 2022, 20:10 |
#22 | |
Sakun
Rep Power: 7 |
sorry for commenting on an old thread, did you get the solution for your problem ? cause i have use 2 pressure values as well. |
rhosimplefoam error |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 03:23 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
