interDyMFoam Floating Object with snappyHexMesh not working
Old   May 24, 2016, 12:29
Default interDyMFoam Floating Object with snappyHexMesh not working
Rafael
ocalloc is on a distinguished road
I'm trying to run a case similar to the floating object tutorial but I'm having some problems.
In place of a box, the geometry is a box with a small hole. The objective is to see how a ship behaves when one tank is flooded.
I'm getting this error when I run interDyMFoam
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
I've already seem similar problems in this forum but couldn't find a solution. Any help will be appreciated.
Here is my case file, if you want to take a further look.
https://www.dropbox.com/s/5yqsg9vph3...model.tar?dl=0
Thanks
ocalloc is offline   Reply With Quote
Old   May 27, 2016, 10:42
Rafael
I've managed to run interDyMFoam for a simpler geometry with fair results. So I tend to think that the problem is with the mesh, tough I can't imagine what is the problem with the mesh.
The programed also converged when using interFoam.
I'm still waiting for any guidance.
Thanks
floating object, interdymfoam, snapphexmesh
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
Is OpenFOAM capable to simulate a floating object with variable density? Idosar OpenFOAM 0 September 29, 2015 17:13
falling object in interdymfoam jinyaqing OpenFOAM Running, Solving & CFD 0 October 8, 2014 13:06
plotting "p_rgh vs time" under a floating object kilroy OpenFOAM Post-Processing 0 June 28, 2013 17:17
