simpleFoam: error while loading shared libraries...
Old   May 22, 2016, 09:21
Default simpleFoam: error while loading shared libraries...
Klaus
klausb will become famous soon enough
I keep running into the same problem since I updated the Qt installation which was completely unrelated to OpenFoam and maybe it's unrelated to the problem also! Initially I was thinking, that the installation is messed up for some reason but I can't find an error.
I keep getting the following error:
simpleFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory
All tutorials and my own simulation which ran without any issues on my OF 2.4 installation, no matter whether I try to run them on one or multiple cores results in the same error.
If I look at the installation, everything (like some experimentally turbulence models I use) seems to be in place.
The bashrc entry is there, parafoam works fine, $FOAM_RUN, ompi_info, $WM_PROJECT_DIR produce the correct results/path hence I can't figure out what's causing the problem or where OF tries to locate shared objects ?!
Any ideas?
Klaus
klausb is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 05:01
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
