InterFoam : Calculate heat/concentration flux at the interface
Old   May 21, 2016, 17:02
Default InterFoam : Calculate heat/concentration flux at the interface
Vietazz is on a distinguished road
Hello everyone,
I am using interFoam to simulate mass transfer from a rising droplet in a quiscent immiscible liquid.
I succeeded to implement the concentration equation in the interfoam solver ! Resulats are pretty good !
Nom I'd like to post-process the integral of the concentration flux around the interface so I can calculate the Sherwood numbder (the equivalent of the Nusselt number in thermal problem) . I searched for a solution evreywhere without a result !!
I'll be really grateful to whoever may suggest a piece of help
Sincerly,
Vietazz is offline   Reply With Quote
Old   May 23, 2016, 09:30
I am really stuck ! can anybody help plz ..?
Here is what I wanna do :
I am trying to calculate the integrale of D.\nabla (C)*n over the region where alpha=1.
C : concentration
D : diffucivity
n : normal unit vector to the interface
* : inner product
I will appreciate any help ...
Old   September 5, 2017, 14:09
Default Hi friend
Phanindra
phani45 is on a distinguished road
My project also involves similar work. can you please share your concentration equation code with me.
my-email: phanindra45@gmail.com
phani45 is offline   Reply With Quote
Old   March 22, 2023, 14:28
Santhosh
Santhosh91 is on a distinguished road
Hey guys !
Did you manage to implement this concentration equation in interFoam ? If yes, would you mind share the code or the process ? I am stuck with the same problem.
Sincerely,
Santhosh
Santhosh91 is offline   Reply With Quote
concentration flux, interfoam, openfoam
How to apply heat flux at the interface when using VOF method? princekar FLUENT 0 November 15, 2015 08:47
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
heat flux on fluid-solid interface does not match Dai CFX 4 October 30, 2006 09:38
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
