Problem in integration of GPU based solver with OpenFOAM
Old   May 17, 2016, 03:13
Default Problem in integration of GPU based solver with OpenFOAM
Puja
puja.khirodkar is on a distinguished road
Hi all....
I am trying to integrate my GPU based Conjugate Gradient SOlver in CUDA with OpenFOAM-2.4.0 using PARALUTION-1.0.0 library. But I am facing problem in linking CUDA (.cu) file with .C file .
My file structure is as follows:
new_PCG.C is an OpenFOAM file wherein input is generated and it calls a cg( ) function from conjGrad.cu (CUDA File) file . I have given a path of new_PCG.C in Make/files . To compile conjGrad.cu,I made a shared object (.so) file and given its path in Make/Options . But still it cannot find cg( ) function. It may be because the linking is not done here .
Can anyone suggest me the way I can do this?
puja.khirodkar is offline   Reply With Quote
Old   May 17, 2016, 04:03
W.T
dybuk is on a distinguished road
There is a CUDA solvers for foam-extended based on cusp library. Source code can be found in foam-extend repo or on github :
https://github.com/Benjamin-git/cufflink-library
If you analyze code you should find some clues
dybuk is offline   Reply With Quote
Old   December 12, 2022, 07:37
Default integration of cufflink to OpenFOAM
Nitish25 is on a distinguished road
Hi can you kindly tell me the procedure to get the "Integrating OpenFOAM and GPUs using cufflink library"
Thanks
Nitish25 is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to rewrite a standard OpenFOAM solver as a C++ class cfbaptista OpenFOAM Programming & Development 7 March 23, 2016 05:50
Problem with the convergence of the solver DOliveira OpenFOAM Running, Solving & CFD 3 November 9, 2015 12:25
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
