flapping console "inverted" on icoFsiElasticNonLinULSolidFoam: FPE
Old   May 7, 2016, 09:57
Default flapping console "inverted" on icoFsiElasticNonLinULSolidFoam: FPE
thegauravonline's Avatar
GS
thegauravonline is on a distinguished road
Floating Point Error
original configuration of flapping console working fine in icoFsiElasticNonLinULSolidFoam solver, however when making changes to its geometry i.e. inverting the flap upside down blockMesh generates correct geometry but on execution i get Floating Point Error on the very first iteration of first time step.
What could possibly be the reason.
attaching here the blockMesh files
blockMeshDict Original:
convertToMeters 0.01;
vertices
    (-3    0   -2.4)
    (0     0   -2.4)
    (0.04  0   -2.4)
    (6    0   -2.4)
    (-3   1.6  -2.4)
    (0    1.6  -2.4)
    (0.04 1.6  -2.4)
    (6   1.6  -2.4)
    (-3   2.6  -2.4)
    (0    2.6  -2.4)
    (0.04 2.6  -2.4)
    (6   2.6  -2.4)
    (-3    0   2.4)
    (0     0   2.4)
    (0.04  0   2.4)
    (6    0   2.4)
    (-3   1.6  2.4)
    (0    1.6  2.4)
    (0.04 1.6  2.4)
    (6   1.6  2.4)
    (-3   2.6  2.4)
    (0    2.6  2.4)
    (0.04 2.6  2.4)
    (6   2.6  2.4)
blocks
    hex (0 1 5 4 12 13 17 16) (40 20 1) simpleGrading (0.1 0.2 1)
    hex (2 3 7 6 14 15 19 18) (80 20 1) simpleGrading (10 0.2 1)
    hex (4 5 9 8 16 17 21 20) (40 20 1) simpleGrading (0.1 2 1)
    hex (5 6 10 9 17 18 22 21) (5 20 1) simpleGrading (1 2 1)
    hex (6 7 11 10 18 19 23 22) (80 20 1) simpleGrading (10 2 1)
edges
patches
    patch plate
        (1 13 17 5)
        (5 17 18 6)
        (6 18 14 2)
    wall topWall
        (8 20 21 9)
        (9 21 22 10)
        (10 22 23 11)
    wall bottomWall
        (0 1 13 12)
        (2 3 15 14)
    patch outlet
        (3 7 19 15)
        (7 11 23 19)
    wall inlet
        (0 12 16 4)
        (4 16 20 8)
    wall frontAndBackPlanes
	(0 4 5 1)
	(4 8 9 5)
	(5 9 10 6)
	(2 6 7 3)
	(6 10 11 7)
	(12 13 17 16)
	(16 17 21 20)
	(17 18 22 21)
	(14 15 19 18)
	(18 19 23 22)
mergePatchPairs
blockMeshDict 'Inverted'
vertices
    (-3   2.6   -0.1)
    (0    2.6   -0.1)
    (0.04 2.6  -0.1)
    (6   2.6   -0.1)
    (-3   1.0  -0.1)
    (0    1.0  -0.1)
    (0.04 1.0  -0.1)
    (6   1.0  -0.1)
    (-3    0  -0.1)
    (0     0  -0.1)
    (0.04  0  -0.1)
    (6    0  -0.1)
    (-3   2.6   0.1)
    (0    2.6   0.1)
    (0.04 2.6   0.1)
    (6   2.6   0.1)
    (-3   1.0   0.1)
    (0    1.0   0.1)
    (0.04 1.0   0.1)
    (6   1.0   0.1)
    (-3    0    0.1)
    (0     0    0.1)
    (0.04  0    0.1)
    (6    0    0.1)
blocks
    hex (0 1 5 4 12 13 17 16) (40 40 1) simpleGrading (0.1 0.2 1)
    hex (2 3 7 6 14 15 19 18) (80 40 1) simpleGrading (10 0.2 1)
edges
patches
    patch plate
        (1 5 17 13)
        (5 6 18 17)
        (6 2 14 18)
    wall topWall
        (8 9 21 20)
        (9 10 22 21)
        (10 11 23 22)
    wall bottomWall
        (0 12 13 1)
        (2 14 15 3)
    patch outlet
        (3 15 19 7)
        (7 19 23 11)
    wall inlet
        (4 8 20 16)
	 (0 4 16 12)
	(0 1 5 4)
	(4 5 9 8)
	(5 6 10 9)
	(2 3 7 6)
	(6 7 11 10)
	(12 16 17 13)
	(16 20 21 17)
	(17 21 22 18)
	(14 18 19 15)
	(18 22 23 19)
mergePatchPairs
Error:
Time = 0.001
Selecting coupling scheme Aitken
Time = 0.001, iteration: 1
Current fsi under-relaxation factor: 0.01
Maximal accumulated displacement of interface points: 0
Courant Number mean: 0 max: 0.245296 velocity magnitude: 2.5
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 8.4538e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.999966, Final residual = 1.7792e-07, No Iterations 4
GAMG:  Solving for p, Initial residual = 1, Final residual = 7.80704e-07, No Iterations 86
GAMG:  Solving for p, Initial residual = 1.98235e-09, Final residual = 1.88759e-09, No Iterations 1
time step continuity errors : sum local = 5.84421e-10, global = 1.62721e-10, cumulative = 1.62721e-10
GAMG:  Solving for p, Initial residual = 0.00487597, Final residual = 7.22372e-07, No Iterations 42
GAMG:  Solving for p, Initial residual = 8.50265e-07, Final residual = 8.30156e-07, No Iterations 1
time step continuity errors : sum local = 2.19309e-07, global = -6.11314e-08, cumulative = -6.09687e-08
Setting traction on solid patch
Total traction force = (0.228999 0.222553 0)
Floating point exception
Please help!!!
File Type: jpg Screenshot from 2016-05-07 18:26:53.jpg (16.0 KB, 8 views)
thegauravonline is offline   Reply With Quote
Old   May 7, 2016, 13:32
Troy Snyder
tas38 is on a distinguished road
What is the output of checkMesh?
tas38 is offline   Reply With Quote
Old   May 8, 2016, 10:36
GS
checkMesh
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    all points:           15052
    live points:          15052
    all faces:            29425
    live faces:           29425
    internal faces:       14375
    cells:                7300
    boundary patches:     6
    point zones:          0
    face zones:           1
    cell zones:           0
Overall number of cells of each type:
    hexahedra:     7300
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Area [m^2]  Surface topology
    plate               85       172      6.48e-05    ok (non-closed singly connected)
    topWall             125      252      0.00018     ok (non-closed singly connected)
    bottomWall          120      244      0.0001792   ok (non-closed singly connected)
    outlet              60       122      5.2e-05     ok (non-closed singly connected)
    inlet               60       122      5.2e-05     ok (non-closed singly connected)
    frontAndBackPlanes  14600    15052    0.0046672   ok (non-closed singly connected)
Checking geometry...
    This is a 3-D mesh
    Overall domain bounding box (-0.03 0 -0.001) (0.06 0.026 0.001)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Mesh (non-empty, non-wedge) dimensions 3
    Boundary openness (2.22144e-18 9.4564e-18 -5.90821e-16) Threshold = 1e-06 OK.
 ***High aspect ratio cells found, Max aspect ratio: 23062.9, number of cells 7300 Threshold = 1000
  Writing 7300 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 2.7668e-08. Maximum face area = 3.79791e-06.  Face area magnitudes OK.
 ***Zero or negative cell volume detected.  Minimum negative volume: -3.04009e-09, Number of negative volume cells: 7300
  Writing 7300 zero volume cells to set zeroVolumeCells
    Mesh non-orthogonality Max: 180 average: 180 Threshold = 70
 ***Number of non-orthogonality errors: 14375.
  Writing 14375 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 43800 faces are incorrectly oriented.
  Writing 29425 faces with incorrect orientation to set wrongOrientedFaces
    Max skewness = 4.51793e-05 OK.
Failed 4 mesh checks.
End
Old   May 9, 2016, 06:13
Default Solved
GS
Seems like i had faces of solid misoriented in the blockMesh.
Sorted that out.
working fine now
DEFINE_CG_MOTION for flapping wing UDF xyzch001 Fluent UDF and Scheme Programming 21 February 7, 2022 08:47
Using simulation to determine thrust vs flapping amplitude relation quarkz Main CFD Forum 1 November 19, 2015 08:18
CFD of flapping wing mav sultan Main CFD Forum 12 February 28, 2013 20:01
UDF for flapping element behind a cylinder Ravi FLUENT 0 June 14, 2006 03:27
CFX-5: Output in a console window cfd guy CFX 2 April 24, 2002 09:11
