ChtmultiRegionSimpleFoam: Run crashed when velocity is high
Old   May 3, 2016, 13:32
Default ChtmultiRegionSimpleFoam: Run crashed when velocity is high
ThomasL is on a distinguished road
Hy everyone,
I'm using OF 2.3.1 to perform some heat transfer calculations in high velocity conditions. I try to perform a canonical case based on a 2D turbulent flow on a 2D plate. I used chtMultiRegionSimpleFoam to perform this simulation but when the velocity is greater than 20m/s, the solver crashes.
I can see some "pressure bumps" within the domain coming from the outlet where a zeroGradient BC is used on the velocity field and a fixedValue BC is used to impose the pressure.
I removed turbulence modeling (KOmegaSST), temperature gradient through the plate (isothermal case), symmetry patch on the top of the numerical domain without any changes.
Do you have any ideas to solve this problem ?
I'm coming from the LES community and this is my first steady simulation .
Thanks a lot
Thomas
ThomasL is offline   Reply With Quote
chtmultiregionsimplefoam, heat and mass transfer, openfoam
high velocity for natural convection sadjad.s FLUENT 4 November 25, 2015 02:34
the fluent was crashed and disapeared when run UDF hongfu2233 Fluent UDF and Scheme Programming 4 January 18, 2015 04:07
How to get cut plane of velocity from axisymmetric run aerospain OpenFOAM Post-Processing 0 November 20, 2012 08:02
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
recovering monitor data from a crashed run prabhu CFX 1 February 21, 2008 19:08
