Translational movement of geometry
Old   May 3, 2016, 08:43
Default Translational movement of geometry
Storro is on a distinguished road
Hi everybody,
i am trying to create a simulation case, where there is a solid translating throug the air into an other fluid.
In the first step i'm trying to realize the movement of the solid.
The movement is similar to the movement in the movingCone tutorial. But in this tutorial the mesh is deforming. In my case the movement of the geometry is bigger, so the mesh is getting really bad, if i'm doing it the same way like in the movingCone Tutorial. For a rotating movement there is the possibility with the dynamic Mesh, but for translating i couldn't recieve a good mesh after the translation. So my question is: Is there an other possibility to realize a translation?
I was also thinking about translating the geometry befor meshing and make different simulations für each step of the moved geometry, but this will need a lot of computational power.
Because i'm planning to make a multiphase simulation i used the interDyMFoam for the translation.
I'm happy for any information you can give to me
Greetings
Kai
Storro is offline   Reply With Quote
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
