Updating the turbulent schmidt number in dynamic smagorinsky model
Old   May 2, 2016, 20:23
Default Updating the turbulent schmidt number in dynamic smagorinsky model
Pavan
pvpnrao is on a distinguished road
I am trying to simulate a LES for density current case (driving force is density difference not pressure difference) . Using the Boussinesq approximation.
I am using the dynamic Smagorinsky library uploaded by Alberto. The library calculates the Smagorinsky constant in real time.
I understand that we need a dynamic process to calculate and update the Turbulent Schmidt number as well. That will help us in calculating the SGS flux in the filtered scalar transport equation for density transport
I am wondering if somebody has used dynamic Smagorinsky library for density currents and wrote the subroutine for updating the Turbulent Schmidt number as well (as described in Moin's 1991 paper).
On a separate note: Do you think this updation is required at all. What will be consequences of using a constant value for Turbulent Schmidt number.
pvpnrao is offline   Reply With Quote
Old   May 3, 2016, 19:46
Pavan
Can anyone please provide some information
Old   November 5, 2020, 13:11
Tian Jin
Tian Jin is on a distinguished road
Hello, have you solved it? I have the same question here.
Tian Jin is offline   Reply With Quote
Old   November 6, 2020, 04:52
Santiago Lopez Castano
Santiago is on a distinguished road
Hello guys, I have recently published some work related to SGS modelling of turbulent scalar transport in Buoyant flows:
Check it out! PM me if you are interested in details.
Santiago is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
