April 25, 2016, 08:31 |
Regarding rhoCentralFoam
Gopal Shinde
Rep Power: 17 |
Hi Foamers,
I have a question. It is like this : I am running the rhoCentralFoam for the flow simulation over OneraM6 wing. The output of the solver is attached below ================================================== ============= Starting time loop forceCoeffs forces: Not including porosity effects Mean and max Courant Numbers = 1.747831e-05 0.03413952 Time = 1e-08 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 ExecutionTime = 8.03 s ClockTime = 8 s forceCoeffs forces output: Cm = 9.136184e-05 Cd = 0.0003770677 Cl = 0.0007398541 Cl(f) = 0.0004612889 Cl(r) = 0.0002785652 Mean and max Courant Numbers = 1.747831e-05 0.03415259 Time = 2e-08 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 ExecutionTime = 11.02 s ClockTime = 11 s ================================================== ============ The solver log shows initial residual and final residual as ZERO(as seen above). Why is that so ? Plz help. Gopal. |
compressible flow, residual, rhocentralfoam |
How to apply a turbulence model to the rhoCentralFoam solver? | arussell92 | OpenFOAM Pre-Processing | 18 | July 25, 2022 05:26 |
Modify rhoCentralFoam: other equations of state | fivos | OpenFOAM Programming & Development | 5 | July 29, 2020 14:17 |
cavity using rhoCentralFoam | Moslem | OpenFOAM Verification & Validation | 0 | July 5, 2015 06:55 |
dynamic mesh refinement and rhoCentralFoam | ChrisA | OpenFOAM Running, Solving & CFD | 1 | March 21, 2013 09:00 |
rhoCentralFoam solver with Slip BCs fails in Parallel Only | JLight | OpenFOAM Running, Solving & CFD | 2 | October 11, 2012 22:08 |
