Run OpenFoam in 2 nodes of a cluster
Old   April 22, 2016, 12:22
Default Run OpenFoam in 2 nodes of a cluster
WhiteW is on a distinguished road
Hi I'm trying to set and run a simulation of OpenFoam in a cluster (2nodes 16cores per node).
I'm using qsub and a pbs script. However if I don't specify a host file it runs 32 thread in the first node.
When I specify an host file it doesn't run.
These are the commands in my startjob.pbs:
#!/bin/bash -l
#PBS -N AOC_OF
#PBS -S /bin/bash
#PBS -l nodes=2:ppn=16
#PBS -l walltime=999:00:00
module load openmpi-x86_64
source /home/whitew/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI
cd $PBS_O_WORKDIR
#mpirun --hostfile hosts.txt -np 32 simpleFoam -parallel > log.simpleFoam_1st
mpirun --host node6,node7 -np 32 simpleFoam -parallel > log.simpleFoam_1st
This is the hosts.txt file in the main folder (the same of startjob):
node6
node7
where I'm doing wrong?
thanks in advance,
WhiteW
WhiteW is offline   Reply With Quote
Old   May 1, 2016, 06:35
Has nobody tried to set OF to run on 2 or more nodes?
Thanks,
WhiteW
Old   May 1, 2016, 18:26
Retired Super Moderator
Bruno Santos
Quick answer: Notes about running OpenFOAM in parallel - using foamExec might solve the issue. I know I have this written somewhere in a thread... here's an example: http://www.cfd-online.com/Forums/ope...tml#post504516 - post #7
Found it with the following on Google:
site:cfd-online.com "wyldckat" "foamExec" parallel
Old   May 2, 2016, 07:37
Thanks for the help Bruno, I have added the path to foamExec in the comand, however it doesn't work.
When I run the startjob (qsub startjob.pbs) with inside the comand:
mpirun --hostfile hosts.txt /home/whitew/OpenFOAM/OpenFOAM-2.3.0/bin/FoamExec simpleFoam -parallel > log.simpleFoam_1st
The process is running in qstat (label R), but checking "qstat -n" it seems to run on node1 and node2 (in machines.txt I have specified node6 and node7). However if I enter in node1 and node2 OF is not running and an empty logfile of 0kb has been created.
When I try to run the mpi command directly from the frontend of the cluster, without using qsub, I have the following errors:
[node7:12516] Error: unknown option "--tree-spawn"
input in flex scanner failed
[node6:55424] Error: unknown option "--tree-spawn"
Have I to install foam-extend? I have only OpenFOAM 2.3.0 installed in the cluster.
Thanks,
WhiteW
Old   May 3, 2016, 18:06
Bruno Santos
Quick answer: I suspect that the problem will reveal itself if you use this command:
mpirun --hostfile hosts.txt /home/whitew/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
Because:
  1. Your command had "FoamExec" instead of "foamExec".
  2. At the end of the line I added this:
    2>&1
    which redirects the textual error output stream (2) into the standard text output stream (1). This way the actual error messages will be stored into the log file.
Old   May 4, 2016, 04:24
Thanks for the explanation!
I have run the correct command and now the error is written in the logfile; however it reports the same error:
[node7:21261] Error: unknown option "--tree-spawn"
[node6:67200] Error: unknown option "--tree-spawn"
Could it be an OF problem or is it a mpirun issue?
WhiteW
Old   May 6, 2016, 05:23
Hi banji. To write the output in a file you have to run:
mpirun -np 4 pisoFoamIPM -parallel >logfile.txt
[ Moderator note: this part of the text was copied to here: http://www.cfd-online.com/Forums/ope...tml#post599206 ]
I'm still trying to run OF on the two nodes of the cluster, still no success.
Using:
mpirun -np 32 --hostfile hosts2.txt /home/whitew/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
Error:
/home/whitew/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec: line 145: exec: simpleFoam: not found
Using the --prefix option:
mpirun --hostfile hosts2.txt --prefix /opt/ofed154/mpi/gcc/openmpi-1.4.3/bin/ /home/whitew/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st >2&1
Error:
bash: /opt/ofed154/mpi/gcc/openmpi-1.4.3/bin/bin/orted: No such file or directory
A daemon (pid 33250) died unexpectedly with status 127 while attempting
to launch so we are aborting.
There may be more information reported by the environment (see above).
This may be because the daemon was unable to find all the needed shared
libraries on the remote node. You may set your LD_LIBRARY_PATH to have the
location of the shared libraries on the remote nodes and this will
automatically be forwarded to the remote nodes.
mpirun noticed that the job aborted, but has no info as to the process
that caused that situation.
mpirun was unable to cleanly terminate the daemons on the nodes shown
below. Additional manual cleanup may be required - please refer to
the "orte-clean" tool for assistance.
    node6 - daemon did not report back when launched
    node7 - daemon did not report back when launched
How to set correctly the LD_LIBRARY_PATH?
Someone solved, adding in the first line of bashrc:
source /whitew/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
However, this has no effect..
Are there other solutions to solve the problem?
Thanks,
WhiteW
Old   May 6, 2016, 05:34
Olabanji
banji is on a distinguished road
Originally Posted by WhiteW View Post
[CODE]
Thanks,
WhiteW
I once had a similar problem and noticed it was as a result of conflicting libraries - local vs OpenFoam's. I'd suggest you recompile the source pack again (if this won't cause too much pain).
Last edited by wyldckat; May 8, 2016 at 16:19. Reason: removed excess part of the quote and left only the essential part
banji is offline   Reply With Quote
Old   May 8, 2016, 16:13
Bruno Santos
Thanks,
WhiteW
Quick answer: I'm so sorry, I completely forgot about what installation instructions you were following
Please run the following commands, which will populate the "prefs.sh" file at OpenFOAM's "etc" folder:
cd /home/whitew/OpenFOAM/OpenFOAM-2.3.0/etc/
echo export WM_NCOMPPROCS=4 > prefs.sh
echo export foamCompiler=ThirdParty >> prefs.sh
echo export WM_COMPILER=Gcc48 >> prefs.sh
echo export WM_MPLIB=SYSTEMOPENMPI >> prefs.sh
This will fix the problem with mpirun being a bit clueless about which specific settings to use with OpenFOAM.
As for foamExec, there is a small fix that might be useful to do as well:
  1. Edit the file "bin/foamExec" inside the "OpenFOAM-2.3.0" folder.
  2. In the very first line, change this:
    #!/bin/sh
    to this:
    #!/bin/bash
This will ensure that the correct shell is used for launching OpenFOAM's utilities.
Old   May 10, 2016, 09:46
Hi, I have written the modifications you suggested.
Now using the source in bashrc (source /home/whiteW/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc) and the modifications in foamExec and prefs.sh
Error:
/home/whiteW/OpenFOAM/OpenFOAM-2.3.0/etc/config/settings.sh: line 384: mpicc: command not found
That line of setting.sh reports:
libDir=`mpicc --showme:link | sed -e 's/.*-L\([^ ]*\).*/\1/'`
Then I have compiled prefs.sh with chmod +x and run. The error now is:
It looks like orte_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  orte_util_nidmap_init failed
  --> Returned value Data unpack had inadequate space (-25) instead of ORTE_SUCCESS
[node3:35896] [[21228,1],16] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35896] [[21228,1],16] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
  orte_ess_set_name failed
It looks like MPI_INIT failed for some reason; your parallel process is
fail during MPI_INIT; some of which are due to configuration or environment
problems.  This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
  ompi_mpi_init: orte_init failed
  --> Returned "Data unpack had inadequate space" (-25) instead of "Success" (0)
[node3:35896] [[21228,1],16] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35896] *** An error occurred in MPI_Init
[node3:35896] *** on a NULL communicator
[node3:35896] *** Unknown error
[node3:35896] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
An MPI process is aborting at a time when it cannot guarantee that all
of its peer processes in the job will be killed properly.  You should
double check that everything has shut down cleanly.
  Reason:     Before MPI_INIT completed
  Local host: node3
  PID:        35896
[node3:35897] [[21228,1],17] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35897] [[21228,1],17] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35899] [[21228,1],19] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35899] [[21228,1],19] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35897] [[21228,1],17] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35899] [[21228,1],19] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35898] [[21228,1],18] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35898] [[21228,1],18] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35900] [[21228,1],20] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35900] [[21228,1],20] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35900] [[21228,1],20] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35898] [[21228,1],18] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35901] [[21228,1],21] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35901] [[21228,1],21] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35901] [[21228,1],21] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35902] [[21228,1],22] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35902] [[21228,1],22] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35902] [[21228,1],22] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35905] [[21228,1],23] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35905] [[21228,1],23] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35905] [[21228,1],23] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35909] [[21228,1],26] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35909] [[21228,1],26] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35909] [[21228,1],26] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
[node3:35910] [[21228,1],27] ORTE_ERROR_LOG: Data unpack had inadequate space in file util/nidmap.c at line 117
[node3:35910] [[21228,1],27] ORTE_ERROR_LOG: Data unpack had inadequate space in file ess_env_module.c at line 174
[node3:35910] [[21228,1],27] ORTE_ERROR_LOG: Data unpack had inadequate space in file runtime/orte_init.c at line 128
mpirun has exited due to process rank 19 with PID 35899 on
node node3 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[frontend:20585] 9 more processes have sent help message help-orte-runtime.txt / orte_init:startup:internal-failure
[frontend:20585] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[frontend:20585] 9 more processes have sent help message help-orte-runtime / orte_init:startup:internal-failure
[frontend:20585] 9 more processes have sent help message help-mpi-runtime / mpi_init:startup:internal-failure
[frontend:20585] 9 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal unknown handle
[frontend:20585] 9 more processes have sent help message help-mpi-runtime.txt / ompi mpi abort:cannot guarantee all killed
Thanks for the help!
WhiteW
Old   May 10, 2016, 11:00
Mahdi Hosseinali
anishtain4 is on a distinguished road
To run my simulations on a SunGridEngine I use the following script:
#$ -cwd
#$ -l h_rt=47:0:0
#$ -pe ompi* 20
module purge
module load gcc/4.6.4 openmpi/gcc openfoam/3.0
source $OPENFOAM/etc/bashrc
mpirun pimpleFoam -parallel
However you are running on a PBS which may have a different set of commands so the set up might be different (I guess it should only be the top part)
anishtain4 is offline   Reply With Quote
Old   May 10, 2016, 11:11
Hi anishtain4, yes, using pbs it works only if I sent the job in a node (not more that one).
Here is the setting of the pbs files:
If I send the job from the frontend to 1 node it works:
#!/bin/bash -l
#PBS -N AOC_OF_14_M4
#PBS -S /bin/bash
source /home/whiteW/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI
cd $PBS_O_WORKDIR
mpirun -np 32 simpleFoam -parallel > log.simpleFoam_1st
Sending the job to two nodes it gives errors:
#!/bin/bash -l
#PBS -S /bin/bash
#PBS -l nodes=1:ppn=16:NRM
cd $PBS_O_WORKDIR
mpirun -np 16--hostfile hosts2.txt /home/whiteW/OpenFOAM/OpenFOAM-2.3.0/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
Old   May 10, 2016, 19:35
Bruno Santos
Quick answer @WhiteW: Hopefully the following will do the trick:
  1. Edit the file "foamExec" once again.
  2. Near the end of the file you will find these two commands:
    sourceRc
    exec "$@"
  3. Add before the first line the line needed for loading the respective module:
    sourceRc
    exec "$@"
  4. Save the file and close the editor.
As for the job script, here is what I suggest that you use for each scenario, at least based on what you wrote:
  • One node:
    #!/bin/bash -l
    #PBS -S /bin/bash
    cd $PBS_O_WORKDIR
    mpirun -np 32 simpleFoam -parallel > log.simpleFoam_1st 2>&1
  • Two nodes:
    #!/bin/bash -l
    #PBS -S /bin/bash
    cd $PBS_O_WORKDIR
    mpirun -np 16 --hostfile hosts2.txt $WM_PROJECT_DIR/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
    Notes:
    1. You had a small flaw, because you had this:
      16--hostfile
      when it should be this:
      16 --hostfile
      Namely, a space was missing.
    2. Using "$WM_PROJECT_DIR" is only to make it easier to read, because the path should expand automatically to the correct path. You can see this by running:
      echo $WM_PROJECT_DIR
Nonetheless, I believe that there is something incorrectly configured in the line "#PBS -l nodes", at least based on what you provided.
Old   May 11, 2016, 12:55
Thanks!
I have now added the string to foamExec.
However when I run using qsub with the file startjob.pbs:
#!/bin/bash -l
#PBS -S /bin/bash
cd $PBS_O_WORKDIR
mpirun -np 32 --hostfile hosts2.txt $WM_PROJECT_DIR/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
I get the error in logfile:
The strange thing is that in hosts2.txt I have specified:
node2 cpu=16
node3 cpu=16
qstat -n tells me the processes are running on node1 and node2. However in these nodes there are no runing process.
Old   May 13, 2016, 01:37
Mahdi Hosseinali
I'm not an expert in clusters, so these are things that I'm guessing:
1. what is the :NRM after your nodes when running on one node? I noticed it is missing when you are running with two nodes. It's not related? No?
2. I'm not sure if your host file is defined correctly or not? I think it needs to be a list of node names on your cluster, for example mine looks something like this:
"cl083.acenet.ca.7353"
"cl083.acenet.ca.7354"
"cl084.acenet.ca.26982"
"cl084.acenet.ca.26983"
Old   May 13, 2016, 04:01
Hi anishtain4 thanks for the reply,
NRM means that the nodes are automatically assigned to the job, hence you don't have to specify specific nodes.
The job starts correctly if I don't specify the option --hostfile hosts2.txt, however it assignes 32 thread to only one node, he does not divide the processes in two nodes (16 on node1 and 16 on node2)
using both:
#PBS -l nodes=node1:ppn=16+node2:ppn=16
or
and
mpirun -np 32 $WM_PROJECT_DIR/bin/foamExec simpleFoam -parallel > log.simpleFoam_1st 2>&1
the job starts with 32 processes in the first node.
The error about "mpicc: command not found" seems to appear when I specify the --hostfile option.
In the file hosts.txt I have written the name of the nodes as reportd in the file etc/hosts :
192.168.0.1     node1
192.168.0.2     node2
192.168.0.3     node3
192.168.0.4     node4
192.168.0.5     node5
192.168.0.6     node6
192.168.0.7     node7
WhiteW
Old   December 20, 2016, 01:51
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Maybe will help to someone. I have fight with "laplacianFoam not found" environment variables problem and solved it by adding "source ~/.bashrc" to my PBS-file. My PBS-file now:
#!/bin/bash
#PBS -N flange
#PBS -A studtlt
#PBS -l nodes=1:ppn=8
#PBS -l walltime=30:00:00
#PBS -m ae
cd $PBS_O_WORKDIR
module load openmpi-1.4.5
source ~/.bashrc
cd /home/studtlt/avdeev/flange
mpirun -machinefile $PBS_NODEFILE -np $PBS_NP /home/studtlt/OpenFOAM/OpenFOAM-4.0/bin/foamExec laplacianFoam -parallel | tee -a log
and ~/.bashrc has inside
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
        . /etc/bashrc
fi
module load openmpi-1.4.5; source $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc WM_LABEL_SIZE=64 WM_COMPILER_TYPE=ThirdParty FOAMY_HEX_MESH=yes
# User specific aliases and functions
#alias of40='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc WM_LABEL_SIZE=64 WM_COMPILER_TYPE=ThirdParty FOAMY_HEX_MESH=yes'
alias of40='module load openmpi-1.4.5; source $HOME/OpenFOAM/OpenFOAM-4.0/etc/bashrc WM_LABEL_SIZE=64 WM_COMPILER_TYPE=ThirdParty FOAMY_HEX_MESH=yes'
j-avdeev is offline   Reply With Quote
How to run SU2 on cluster of computers (How to specify nodes ?) aero_amit SU2 29 February 24, 2020 14:44
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
OpenFOAM solvers not able to run in parallel raagh77 OpenFOAM Installation 5 November 27, 2013 18:05
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 14:37
