Residuals blowing up for simple turbulent case
Old   April 16, 2016, 22:57
Default Residuals blowing up for simple turbulent case
ss32 is on a distinguished road
I am attempting to model turbulent flow over a cylinder. I created an unstructured mesh in pointwise and imported into openFoam. The geometry is dead simple: A sqaure boundary around a circle.
Boundary Conditions:
Circle - wall
top/bottom (y-axis) front/back (z-axis) - empty
front/back (x-axis) - patch
I have set the front (x-axis) as an inlet and back (x-axis) as outlet and am solving using k-epsilon. The domain is 10 x 10 with the circle being 1 in diameter.
0 directory, all files modified versions of pitzDaily example:
epsilon
|  \\    /   O peration     | Version:  v3.0+                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.00335;
boundaryField
    frontback
        type            empty;
    inlet
        type            fixedValue;
        value           uniform 0.00335;
    outlet
        type            zeroGradient;
    walls
        type            epsilonWallFunction;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (3 0 0);
boundaryField
    frontback
        type            empty;
    inlet
        type            fixedValue;
        value           uniform (3 0 0);
    outlet
        type            zeroGradient;
    walls
        type            fixedValue;
        value           uniform (0 0 0);
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    frontback
        type            empty;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    walls
        type            nutkWallFunction;
        value           uniform 0;
nuTilda
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
boundaryField
    frontback
        type            empty;
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
k
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.00555;
boundaryField
    frontback
        type            empty;
    inlet
        type            fixedValue;
        value           uniform 0.00555;
    outlet
        type            zeroGradient;
    walls
        type            kqRWallFunction;
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    frontback
        type            empty;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    walls
        type            zeroGradient;
The case fails on the first time step with infinite residuals and I'm lost as to why.
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 1e-08
    field U     tolerance 1e-08
    field "(k|epsilon|omega|f|v2)"     tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
streamLine streamLines:
    automatic track length specified through number of sub cycles : 5
Time = 0.0001
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = nan, No Iterations 1000
GAMG:  Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 0 the word 'nan'
ss32 is offline   Reply With Quote
Old   April 17, 2016, 11:14
I have changed the top/bottom to patch and assigned them freestream values, still getting the same problem.
Old   April 18, 2016, 06:59
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
It looks like you are only solving for Ux, which means you are solving for a 1D problem. Please run checkMesh and make sure you have defined your problem correctly.
tomf is offline   Reply With Quote
Old   April 18, 2016, 09:37
Everything looks good, but how do I ensure I'm solving a 2D problem?
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            142845
    internal faces:   60225
    cells:            40614
    faces per cell:   5
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     0
    prisms:        40614
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    frontback           81228    42006    ok (non-closed singly connected)
    inlet               398      798      ok (non-closed singly connected)
    outlet              398      798      ok (non-closed singly connected)
    topbottom           398      800      ok (non-closed singly connected)
    walls               198      396      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-5 -5 0.01) (5 5 0.02)
    Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
    Mesh has 2 solution (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-1.87618e-18 -1.46651e-20 6.08114e-16) OK.
    Max cell openness = 2.42378e-16 OK.
    Max aspect ratio = 6.56347 OK.
    Minimum face area = 5.01428e-05. Maximum face area = 0.0059415.  Face area magnitudes OK.
    Min volume = 5.01428e-07. Max volume = 5.9415e-05.  Total volume = 0.992154.  Cell volumes OK.
    Mesh non-orthogonality Max: 51.6706 average: 8.27031
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.732464 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Old   April 18, 2016, 09:49
Tom Fahner
I take this from your first post
Circle - wall
Which would explain why it is not solving for Uy and Uz: both are empty.
However you claim to have used freestream for topbottom (redefined as type patch) as well and got the same result? Where did you change the patch type? It should be in constant/polyMesh/boundary.
The topbottom is also not mentioned in your boundary conditions from your first post.
Regards,
Tom
Old   April 18, 2016, 11:23
I went into pointwise and redefined the top and bottom and updated all of the relevant files in 0 as well.
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
5
    frontback
        type empty;
        nFaces 81228;
        startFace 60225;
    inlet
        type patch;
        nFaces 398;
        startFace 141453;
    outlet
        type patch;
        nFaces 398;
        startFace 141851;
    topbottom
        type patch;
        nFaces 398;
        startFace 142249;
    walls
        type wall;
        nFaces 198;
        startFace 142647;
simpleFoam log
Create time
    field p      tolerance 1e-05
    field U      tolerance 1e-05
    field nuTilda        tolerance 1e-05
Reading field p
Reading field U
Selecting RAS turbulence model SpalartAllmaras
Selecting patchDistMethod meshWave
SpalartAllmarasCoeffs
    sigmaNut        0.66666;
    kappa           0.41;
    Cb1             0.1355;
    Cb2             0.622;
    Cw2             0.3;
    Cw3             2;
    Cv1             7.1;
    Cs              0.3;
Starting time loop
Time = 0.01
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = nan, No It        erations 1000
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = nan, No It        erations 1000
DICPCG:  Solving for p, Initial residual = nan, Final residual = nan, No Iterati        ons 1001
file: /home/user/OpenFOAM/user-v3.0+/run/tutorials/incompressible/simpleFoam/c        ylinder/system/data.solverPerformance.p at line 0.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleSc        alar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
edit: Let me try changing to k-epsilon and try that...
Old   April 18, 2016, 13:27
Same results for k-epsilon
Old   April 19, 2016, 00:15
In case anyone runs into a similar problem, running renumbermesh first did the trick.
Old   April 19, 2016, 02:58
akidess's Avatar
Anton Kidess
That can't be right, renumberMesh should not influence the result.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 19, 2016, 10:40
Well it did. I don't know if it was a memory issue at the start or what was happening, but a case that wouldn't run past the first time step runs to completion after using
renumberMesh -overwrite
I've successfully run a few cases of different turbulence models and meshes that previously failed for the same reason.
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 13:18
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 04:03
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 04:02
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
