icoFoam with MRF zone
Old   April 16, 2016, 13:33
Default icoFoam with MRF zone
Anonymous
tagabi3 is on a distinguished road
I would like to ask if I can use icoFoam solver with MRF zones? So far I have tried to set up a simple case (I've tried to re-write the mixerVessel2D case), but without any success so far and I'm starting to question if it's possible to use the icoFoam solver with MRF zones.
Furthermore, is it possible to check with which solvers I can use the MRF zones? Or shall I directly look into the code?
Thank you in advance!
Gabor
tagabi3 is offline   Reply With Quote
Old   April 16, 2016, 14:35
Retired Super Moderator
Bruno Santos
Quick answers:
  1. icoFoam is a very basic solver. It's mainly a solver for training. In particular, it's used for training modifying a solver, e.g.: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
    • If you want, you can trying adding "fvOptions" to icoFoam yourself
  2. In principle, you can find which solvers can use "fvOptions" by running this command:
    find $FOAM_SOLVERS -name "*.C" -type f | xargs grep -sl fvOptions
    Nonetheless, you might pick up some solver-related libraries that use it as well.
Last edited by wyldckat; April 16, 2016 at 17:28. Reason: fixed typo "is am very" -> "is a very"
Old   April 16, 2016, 17:12
Anonymous
Thanks!
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
