High pressure values at inlet and Loss of Mass flow at AMIs -- pimpleDymFoam |
April 14, 2016, 08:04 |
Sravan Kumar
Rep Power: 12 |
Hi All,
I have been running centrifugal pump steady and transient case in last few months. Steady case works fine with simpleFoam solver. But I have problem with transient case with pimpleDyMFoam. There is a mass flow loss when fluid is flowing through AMI patches. Also pressure boundary condition is fixed value and zero at outlet, but at inlet the pressure occured is too high. It is almost 5 times more. Inlet boundary condition used is zerogradient. We have calculated the torque values as well. The torque values agree quite well. But pressure values is the only problem. I am sharing the case folder for further refence: https://www.dropbox.com/s/kixdj7oomm...a_135.zip?dl=0 However the case folder cannot be run since I have removed files from polymesh folder. Since I cannot share the geometry details or mesh of the pump. However one have look at the setting I have used. Please help me out in correcting the errors. Please guide where I have gone wrong . Also let me know in case you need any further information |
April 15, 2016, 04:41 |
Sravan Kumar
Rep Power: 12 |
Any help guys
April 15, 2016, 11:26 |
Troy Snyder
Rep Power: 19 |
A more appropriate boundary condition (well-posed) for the inflow patch would be totalPressure for p and pressureInletOutltletVelocity for U if you are not specifying the velocity at the inflow.
April 18, 2016, 02:51 |
Sravan Kumar
Rep Power: 12 |
Hi Troy,
Thanks a lot for replying. I have been using following boundary conditions. For Vel: Inlet -- fixed value of 5.5 Outlet -- zero gradient For p: Inlet -- zero gradient Outlet -- fixed value of 0 Do u suggest me to use some fixed total pressure at inlet, instead of fixed inlet velocity ? Please explain if I am not wrong |
pimple, pimple transient, pimple. openfoam, pimpledymfoam |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 04:43 |
Calculate Density | mumtaz ersan | FloEFD, FloWorks & FloTHERM | 1 | September 17, 2015 04:26 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
