April 13, 2016, 07:25 |
Flat Plate: Simulation is not converging
Luana
I am new in OpenFoam and I am trying to run a case of a 2D flat plate ( see figures) using Sparlat Almaras and SimpleFoam. Could someone give me an idea of what can be wrong with my model and/or set up? I have 2 cases, where the set up are the same, but the velocities Inlet UP and Inlet Down are different. Even after 100000 iterations it seems that is it is not converging. The files are attached. Thank you very much for you help. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (38 0 0); boundaryField { INDOWN { type fixedValue; value uniform (7 0 0); } INLET { type fixedValue; value uniform (38 0 0); } PLATE { type fixedValue; value uniform (0 0 0); } OUTLET { type zeroGradient; } TOP { type fixedValue; value uniform (38 0 0); } BOTTOM { type fixedValue; value uniform (7 0 0); } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { TOP { type zeroGradient; } BOTTOM { type zeroGradient; } INLET { type zeroGradient; } INDOWN { type zeroGradient; } OUTLET { type fixedValue; value uniform 0; } PLATE { type zeroGradient; } frontAndback { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { TOP { type zeroGradient; } BOTTOM { type zeroGradient; } INLET { type zeroGradient; } INDOWN { type zeroGradient; } OUTLET { type zeroGradient;; } PLATE { type fixedValue; value uniform 0; } frontAndback { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object RASProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // RASModel SpalartAllmaras; turbulence on; printCoeffs on; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,nuTilda) bounded Gauss upwind grad(nuTilda); div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-7; relTol 0.001; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-9; relTol 0.01; } "(k|epsilon|omega|Phi|nuTilda)" { solver smoothSolver; smoother GaussSeidel; //maxIter 100; tolerance 1e-9; relTol 0.01; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-9; U 1e-9; nuTilda 1e-9; } } potentialFlow { nNonOrthogonalCorrectors 0; } relaxationFactors { fields { p 0.3; } equations { "(U|k|epsilon|omega|nuTilda)" 0.7; "(U|k|epsilon|omega|nuTilda)Final" 0.7; } } cache { grad(U); } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 100000; deltaT 1; writeControl timeStep; writeInterval 10000; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************************************* // Last edited by wyldckat; April 16, 2016 at 12:49. Reason: Added [CODE][/CODE] markers |
April 14, 2016, 02:14 |
May be this helps!
Akr
Rep Power: 11 |
Using radiation model for simulation of flat plate solar collector | marjanbn | FLUENT | 1 | February 24, 2017 18:22 |
Simulations Flow 3D over Flat plate | baoaero | OpenFOAM | 7 | June 7, 2013 06:53 |
Questions about a Turbulent Flat Plate Case | tstorm | FLUENT | 2 | August 11, 2009 15:16 |
Flat Plate Drag & Lift | Joe | Main CFD Forum | 3 | October 24, 2008 15:17 |
Not getting Simple flat plate simulation using sonicTurbFoam | velan | OpenFOAM Running, Solving & CFD | 1 | September 19, 2008 06:00 |
