simpleFoam stopping before specified endtime
Old   April 12, 2016, 11:10
Default simpleFoam stopping before specified endtime
ss32 is on a distinguished road
All tolerances are set to 1e-13, and it's converging fine, but I would like for it to run until the stop time, not stop at convergence. I have searched around quite a bit and was unable to find anything that helped.
controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10;
deltaT          0.0005;
writeControl    timeStep;
writeInterval   5;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions {
    #include "forceCoeffs"
ss32 is offline   Reply With Quote
Old   April 12, 2016, 11:58
Troy Snyder
tas38 is on a distinguished road
In fvSolution file, within the SIMPLE solver parameters, set the residualControl values to very small numbers (eg. 1e-9). This should keep the solver running until the specified end time.
tas38 is offline   Reply With Quote
Old   April 12, 2016, 12:01
They're already at 1e-12, I'm guessing I should just lower them even more? Just so I know what's going on: It runs until it hits the stop time or achieves the residual condition, correct?
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-12;
        U               1e-12;
        "(k|epsilon|omega)" 1e-12;
Old   April 12, 2016, 12:05
Troy Snyder
Correct.
But may I ask why it is necessary to run until a particular end time? The time really has not meaning in a simpleFoam calculation. It simply functions as a means to iterate on the solution. So running until some particular physical time really does not make sense. If this is desired, you should use pimpleFoam.
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
MPI error with simpleFoam blaise OpenFOAM Running, Solving & CFD 0 November 7, 2015 15:01
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 07:53
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
