Foam-extend solution control
Old   April 10, 2016, 04:44
Default Foam-extend solution control
andrew
armitatz is on a distinguished road
I use laplacianFoam in steady state in openfoam 3.0.1 and when it converges it stops even if it hasn't reached the maximum of timesteps. When I use the same problem in foam extend 3.2 even if it converges and the values don't change it doesn't stop and it goes all the way.
I saw in the src directories of both installations and the solutioncontrol is missing from foam extend. Is there a way to make foam extend stop when it reaches convergence?
armitatz is offline   Reply With Quote
Old   May 12, 2016, 07:00
andrew
anybody yet?
Old   May 13, 2016, 01:14
Mahdi Hosseinali
anishtain4 is on a distinguished road
seems to be a bug, you probably want to report it. Or you can copy the missing part and recompile Openfoam all over again.
anishtain4 is offline   Reply With Quote
Old   May 13, 2016, 02:29
andrew
Thank you for the reply. The problem is not at openFoam but at foam-extend. My question is if convergence control has been implemented in foam-extend and how to enable it is an easy way.
Adding patches to openFoam and foam extend goes beyond my capacity.
Old   June 23, 2016, 13:22
Jack
Jack001 is on a distinguished road
I have the exact same issue. Does anyone know of a solution? I don't feel too confident messing about under the hood of openFoam, but this seems like a really trivial problem, as it should be solved with a simple "if solution field residual < convergenceCriterion then stop".
Anyone?
Jack001 is offline   Reply With Quote
Old   June 24, 2016, 08:05
Jack
Could someone maybe point out how this could be changed in the source code of whatever solver one may be using?
Old   September 2, 2016, 16:00
Martin Beaudoin
mbeaudoin will become famous soon enough
Check under $FOAM_APP/solvers. Search for the string 'convergenceCriterion'.
The source code for the solver simpleFoam is a good example.
Martin
mbeaudoin is offline   Reply With Quote
convergence issues, foam extend, solution control
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 08:52
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
