Floating Point Error Caused By Large Residual
Old   April 10, 2016, 16:11
ss32 is on a distinguished road
Originally Posted by tas38 View Post
If you post an external link of your full case directory, I can quickly try to run in 2.3.0 and see what errors it throws.
I think this may be the quickest way to track down the issue.
Done. This is sitting in $FOAM_TUTORIALS/incompressible/simpleFoam/
https://www.dropbox.com/s/7h1wljfb04...auert.zip?dl=0
Thanks again for all the help
ss32 is offline   Reply With Quote
Old   April 10, 2016, 17:08
Troy Snyder
tas38 is on a distinguished road
Got it to run after a few tweaks. Most notably, changed the pressure solver to PCG to get simpleFoam to proceed a few iterations.
Take a look at the solution after a few iterations, I think the issue resides with the mesh, even so it passes checkMesh.
https://www.dropbox.com/s/rkxw0qqk5l...rtMod.zip?dl=0
tas38 is offline   Reply With Quote
Old   April 10, 2016, 17:14
Great! Looking at the velocity data I'm thinking it's an issue where the grid folds over at the trailing edge and there's a huge discontinuity. That's a huge help and now I know what to work on.
Old   April 10, 2016, 17:22
You say you changed the pressure solver to PCG, where do I make that change? And did you change the turbulenceProperties? I see the old one but yours is missing.
Old   April 10, 2016, 17:26
Troy Snyder
Pressure solver changed in fvSolution file.
Older version (2.3.0) of OpenFOAM uses RASproperties file in lieu of the turbulenceProperties file in v.3.
I only ran a laminar case.
To run in v.3., revert to your original setup with a turbulenceProperties file and no RASproperties file.
Old   April 10, 2016, 17:32
It's a start, I got the first two time steps before it blew up this time. Awesome, I'll get to work on the mesh, thanks man.
Old   April 10, 2016, 17:57
It works! With an O-grid! Jesus what PITA. I'll go back and work on the C-grid but for now I can make some progress
Old   April 10, 2016, 17:59
Troy Snyder
Good stuff.
buoyantSimpleFoam and watertank Tobi OpenFOAM Running, Solving & CFD 100 December 18, 2022 09:15
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 13:12
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
