dieselFoam: "out of temperature range" problem |
April 8, 2016, 16:26 |
Olabanji
Rep Power: 13 |
Hi Foamers,
I am trying to run a simple non-reacting case with dieselFoam in OpenFOAM-1.6-ext. The fuel used is dodecane. Right from the beginning, i get the following error From function janafThermo<equationOfState>::checkT(scalar& T) const in file /home/novakm/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 65 attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 295 Please how do I fix this? |
1.6-ext, dieselfoam, janaf, out of temperature range |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Big problem predicting adiabatic wall temperature (wing, mach 0.33, rhoSimplecFoam) | fredo490 | OpenFOAM Running, Solving & CFD | 7 | May 12, 2022 03:24 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
same static and total temperature problem | preetam69 | FLUENT | 1 | August 15, 2013 18:17 |
Re: Strange Problem in Temperature Contour, continuity residual | yashganatra | Fluent UDF and Scheme Programming | 0 | June 27, 2013 10:17 |
