sprayFoam: How to increase the number of parcels while keeping totalMass fixed
Old   April 8, 2016, 12:22
Default sprayFoam: How to increase the number of parcels while keeping totalMass fixed
Olabanji
banji is on a distinguished road
Hi Foamers,
Please how do I increase the number of parcels in the domain while keeping the total mass introduced by the end of the simulation fixed (as described in dict).
Please note that this is a non-reacting case.
Thanks.
banji is offline   Reply With Quote
Old   April 8, 2016, 13:59
Kaufman
kmefun is on a distinguished road
It might be done by increasing parcelsPerSecond in injectionModels?
kmefun is offline   Reply With Quote
Old   April 8, 2016, 14:59
Olabanji
Thanks Kaufman for the reply.
I have tried your suggestion but it does not work. Infact it gets worse as the mesh is refined i.e. there is a huge drop in total mass after injection.
Could it be a bug - I use OpenFoam-2.3.x by the way
Old   April 8, 2016, 19:16
Kaufman
Could you post your injectionModels setup?
Old   April 8, 2016, 21:11
Olabanji
Sure. Please find below:
injectionModels
//for each model, see src/lagrangian/.. for more details
model1
type coneNozzleInjection;
SOI 0;
massTotal 2.995e-6; //6.0e-6; //total mass to inject
parcelBasisType mass; //number, mass or fixed
injectionMethod disc;
flowType flowRateAndDischarge;
outerDiameter 93.8e-6; //1.9e-4;
innerDiameter 0;
duration 1.6998e-3; //1.25e-3;
position ( 0 0.0495 0 );
direction ( 0 -1 0 );
parcelsPerSecond 20000000; //# of parcels introduced per second
flowRateProfile table
/*(0 0.1272)
(0.00125 3.9213)
(0.001251 0.0000)
(1000 0.0000)
(0 0)
(0.0000002 0.0000431032566444)
(0.0000004 0.0000862040320794)
(0.0000006 0.000129302344916)
(0.0000008 0.000172398213715)
(0.000001 0.000215491656984)
(0.0000012 0.000258582693178)
(0.0016982 0.000132313987523)
(0.0016984 0.000117619006053)
(0.0016986 0.000102922371616)
(0.0016988 0.0000882240883514)
(0.001699 0.0000735241604361)
(0.0016992 0.0000588225920867)
(0.0016994 0.0000441193875571)
(0.0016996 0.0000294145511397)
(0.0016998 0.0000147080871646)
(0.0017 0.0)
(1000 0.0000)
Cd constant 0.88; //0.9;
thetaInner constant 0.0;
thetaOuter constant 10.0;
sizeDistribution
type RosinRammler;
RosinRammlerDistribution
minValue 1e-06;
maxValue 0.00015;
d 0.00015;
n 3;
Also find below an excerpt of my log file - after injection has taken place
Solving 3-D cloud sprayCloud
Cloud: sprayCloud
Current number of parcels = 0
Current mass in system = 0
Linear momentum = (0 0 0)
|Linear momentum| = 0
Linear kinetic energy = 0
model1:
number of parcels added = 4037
mass introduced = 7.25864e-07
Parcels absorbed into film = 0
New film detached parcels = 0
Parcel fate (number, mass)
- escape = 0, 0
- stick = 0, 0
Temperature min/max = 0, 0
Mass transfer phase change = 7.25864e-07
D10, D32, Dmax (mu) = 0, 0, 0
Liquid penetration 95% mass (m) = 0
You'd observe that the mass introduced is not even close to what I specified in the subdict. Also the number of parcels are just too small to get any reasonable result.
Thanks again.
Old   May 17, 2016, 15:17
Olabanji
I think I have resolved the problem. I observed that when running a sprayFoam case in parallel, the way the computational domain is decomposed has a great influence on the result. I am not sure if this has been resolved in later versions but for those using OF2.3. and OF2.4 (or previous), you might notice similar problems.
My take: Decompose the domain such that the injector cell is entirely in one of the sub-domains.
Old   July 26, 2016, 16:00
slint is on a distinguished road
Hello banji,
I can confirm this bug (and your solution) for OpenFOAM-2.4.x!
Best regards
slint is offline   Reply With Quote
number of parcels, sprayfoam
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries vkrastev OpenFOAM Pre-Processing 7 June 2, 2016 16:50
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Stable boundaries marcoymarc CFX 33 March 13, 2013 07:39
