April 8, 2016, 06:59 |
Floating point exception error (core dumped)
Sanjiv Paudel
Rep Power: 11 |
Hi guys,
I am stuck here while doing a simulation using a density based solver in OpenFOAM. What may be the reasons behind it? Has anyone encountered such problem during their test cases, then please share the ideas. The problem is shown here..:con fused: Code:
Create Riemann solver: #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 at ??:? #6 at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 at ??:? Floating point exception (core dumped) |
April 8, 2016, 07:02 |
mhdFoam error
Sanjiv Paudel
Rep Power: 11 |
I also got a similar error in mhdFOAM too.
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #4 at ??:? #5 at ??:? #6 at ??:? #7 at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 at ??:? Floating point exception (core dumped) |
June 21, 2016, 16:44 |
Mesh problem
Behrang Mohajer
Rep Power: 12 |
I think you forgot to define all the Boundary condition in your blockMeshDict.
compressible flow, density based solver, floating point error, openfoam |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
problem with floating point exception (core dumped) in createField!!! | rapierrz | OpenFOAM Programming & Development | 0 | June 24, 2015 04:22 |
Floating point exception in tutorials case | xujr | OpenFOAM Running, Solving & CFD | 0 | May 21, 2015 04:31 |
Error: Floating point exception (core dumped) | jishnuhari25 | OpenFOAM Pre-Processing | 0 | April 27, 2015 04:23 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 20:28 |
