Setting initial pressure with periodic boundaries |
April 8, 2016, 06:40 |
Hi
I've made a mesh with blockMesh that has a periodic inlet and outlet (they have the same shape). I want to drive the flow by a body force only (laminar flow, so icoFoam will suffice I guess), for that I've read that pressureGradientExplicitSource can be used. The velocity I have to set periodic, I do it like this: Code:
wall_inlet { type cyclic; value uniform (0 0 0); } wall_outlet { type cyclic; value value uniform (0 0 0); } |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 09:07 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
