Wrong in fvc::laplacian !!
Old   April 7, 2016, 23:54
Default Wrong in fvc::laplacian !!
Zhanchao Hu
chaochaoyoyo is on a distinguished road
I'm a new user of OpenFOAM. Now I try to calculate fvc::laplacian(lambda,T) in a uniform field (temperature is the same everywhere, lambda is thermal conductivity, a dimensionedscalar). What makes me confused is that fvc::laplacian(lambda,T) is a non-zero field (about order e-22 in more than 100 cells)!
The mesh is generated in Gambit, and it is a uniform 200*200 quadrilateral structure mesh. checkMesh tells me everything is OK.
Any suggestion will be appreciated! Thank you!
chaochaoyoyo is offline   Reply With Quote
Old   April 8, 2016, 02:25
Unhappy
Zhanchao Hu
Could anybody help me?
Old   April 8, 2016, 23:19
Zhanchao Hu
I need help
Old   April 9, 2016, 00:20
Smile
Zhanchao Hu
solved. just use Gauss linear orthogonal for laplacian.
Wrong oriented faces due to opposite face bends? Arnoldinho OpenFOAM 5 August 16, 2012 06:00
Warning: Dynamic zone with wrong CG using 6DOF Manoj Kumar FLUENT 1 August 11, 2012 05:03
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 17:24
Axi-symmetric case gives wrong answer pbryant OpenFOAM Bugs 1 February 14, 2011 22:17
A huge mistake that could ruin my project: wrong turbulence specification Cheeko FLUENT 1 June 12, 2010 08:02
