April 7, 2016, 13:50 |
wrong Cl on airfoil
Rep Power: 10 |
My results of Cl, for every BC's that i have tried, still remain about 1.5, but Cl must be about 1.25. How is possible that? I have a mesh very fine with y+ less than 1. I've found a discussion Why Menter's SST model low-Re issue has not been seriously investigated? in which is suggested to use follow bc's for wall:
-k, fixed value very small -nut, calculated -omega, omegawallfunction For patch FAR_FIELD i've use: -k, turbulentIntensityKineticEnergyInlet with value uniform calculated: 1.5(U*I)^2 -nut, calculated with value uniform 0; -omega, turbulentMixingLengthFrequencyInlet with value uniform: 1/mu*rho*k*(mut/mu)^-1 and mixinglenght calculated from this formula http://www.cfd-online.com/Wiki/Turbulence_length_scale My angle of attack is 13° so: liftDir (-0.22495 0.97437 0); dragDir (0.97437 0.22495 0); Questions: 1) Do you validate these bc's and formula for my case? 2)Why did i have about same results of Cl with different bc's like nutkwallfunction, nutuspaldingwallfunction, nutlowre for nut and kqrwallfunction for k? 3)Could be the cause in fvschemes or fvsolution? Please, help me, i have wasted a lot of time for this problem, i can't imagine what else i have to change!! |
April 7, 2016, 13:52 |
my fvschemes and fvsolution
Rep Power: 10 |
ddtSchemes
{ default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; k 1e-5; omega 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.5; k 0.5; omega 0.5; } } |
April 8, 2016, 06:50 |
angle of attack of 13 degrees => do you expect to have stall or maybe partial separation? If so, you maybe should try to run at a lower angle of attack. It is difficult to get correct stall behavior with RANS.
April 8, 2016, 07:22 |
Rep Power: 10 |
No, the flux is attached
April 8, 2016, 07:43 |
Is it attached in the experiment, in the CFD run or anywhere else? Any problems with checkMesh?
You may want to try Code:
div(phi,k) bounded Gauss limitedLinear 1; div(phi,omega) bounded Gauss limitedLinear 1; Code:
div(phi,U) bounded Gauss GammaV 0.2; Tom |
April 8, 2016, 11:22 |
Rep Power: 10 |
I haven't try this changes yet, but i can't believe about my successive tests!!! I have changed mixinglenght, with another more large, 5.24e-3. I have still achieved the same Cl og 1.5 about!!! But the worse is that i have put an absurd mixinglenght of 100, and the result is incredibly the same!!! That's crazy!!!! This is no sense,I haven't words to explain this absurdity! Please, help me!!
April 8, 2016, 12:55 |
Rep Power: 10 |
My current dat are:
K dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0025847; boundaryField { TRAILING_EDGE { type fixedValue; value uniform 1e-12; } SUCTION_SIDE { type fixedValue; value uniform 1e-12; } FAR_FIELD { type turbulentIntensityKineticEnergyInlet; intensity 0.001; value uniform 0.0025847; } PRESSURE_SIDE { type fixedValue; value uniform 1e-12; } frontAndBackPlanes { type empty; } } NUT dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { TRAILING_EDGE { type calculated; value uniform 0; } SUCTION_SIDE { type calculated; value uniform 0; } FAR_FIELD { type calculated; value uniform 0; } PRESSURE_SIDE { type calculated; value uniform 0; } frontAndBackPlanes { type empty; } } OMEGA dimensions [0 0 -1 0 0 0 0]; internalField uniform 1769.45; boundaryField { TRAILING_EDGE { type omegaWallFunction; value uniform 1769.45; } SUCTION_SIDE { type omegaWallFunction; value uniform 1769.45; } FAR_FIELD { type turbulentMixingLengthFrequencyInlet; mixingLength 0.4; value uniform 1769.45; } PRESSURE_SIDE { type omegaWallFunction; value uniform 1769.45; } frontAndBack { type empty; } } P dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { TRAILING_EDGE { type zeroGradient; } SUCTION_SIDE { type zeroGradient; } FAR_FIELD { type freestreamPressure; } PRESSURE_SIDE { type zeroGradient; } frontAndBackPlanes { type empty; } } U imensions [0 1 -1 0 0 0 0]; internalField uniform (40.447 9.338 0); // (41.511*cos13 41.511*sin13) boundaryField { TRAILING_EDGE { type fixedValue; value uniform (0 0 0); } SUCTION_SIDE { type fixedValue; value uniform (0 0 0); } FAR_FIELD { type freestream; freestreamValue uniform (40.447 9.338 0); } PRESSURE_SIDE { type fixedValue; value uniform (0 0 0); } frontAndBackPlanes { type empty; } } |
April 11, 2016, 08:55 |
Rep Power: 10 |
Do you think that for omega's bc at wall i have to use Menter's recommended wall BC, i. e. omegawall=60*nu/(beta*y^2), with nu=kinematic viscosity at the wall, beta=0.075 and y=normal distance between the first fluid node and the nearest wall ? But how i can calculate y and nu at wall? Is the same of nu calculated with mu/rho?
Or if i want use omegawallfunction i have before implement the code with: omega[faceCellI] = omegaLog; i refer to this discussion Why Menter's SST model low-Re issue has not been seriously investigated? |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 17:17 |
udf error | srihari | FLUENT | 1 | October 31, 2016 15:18 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 11:45 |
Validation plunging airfoil - Forces are wrong!!! | wiedangel | OpenFOAM Running, Solving & CFD | 3 | March 3, 2015 13:34 |
Wrong forces on a 2D airfoil using interPhaseChangeFoam | Artur | OpenFOAM | 0 | August 7, 2013 12:38 |
