Divergence scheme for high reynolds number LES |
April 4, 2016, 09:50 |
Balajee
Rep Power: 13 |
Hi
Can anyone tell me which divergence scheme in openfoam to use for high reynolds number LES. upwind cannot be used because of dissipation linear cannot be used due to peclet number criteria ( too many number of cells to satisfy it) I need a good validated scheme. |
April 4, 2016, 12:32 |
#2 | |
Mahdi Hosseinali
Rep Power: 18 |
Upwind method can be used if you use implicit LES (Furbey et al.) Peclet number is not an issue since the diffusion is not being solved explicitly. Higher order central discretizations would've had the Peclet issue if it was the case. |
April 29, 2020, 14:01 |
#3 | |
navid toussi
Rep Power: 11 |
April 29, 2020, 14:08 |
Santiago Lopez Castano
Rep Power: 16 |
April 29, 2020, 14:57 |
navid toussi
Rep Power: 11 |
divergence, peclet number |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
Obtaining Reynolds Number in FLUENT | Emmanuel | FLUENT | 2 | April 7, 2016 02:46 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 07:39 |
CFX Solver Reynolds Number | haider760 | CFX | 2 | March 4, 2012 23:05 |
