velocity inlet in SRF like "U" file in MRF
Old   March 31, 2016, 06:12
Default velocity inlet in SRF like "U" file in MRF
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
I am trying to simulate a Axial flow in a concentric annulus with inner rotating cylinder. For clarity pls see the image below.
[IMG][/IMG]
inner cylinder is rotating while there is incoming flow.
Since i have only a rotating inner wall i think SRF should be enough but i dont know how to give a inlet velocity (U file ) in addition to a relative wall velocity (Urel file). I have browsed through the tutorials in MRF and SRF. MRF contains the U file to specify inlet flow while SRF tutorials dont have. It would be highly appreciative if someone can suggest some ideas. Also please correct me if i am wrong in choosing SRF.
Thank you very much
Regards,
Ananthakrishnan
Ananthakrishnan is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
