How to fix problem with "decomposePar: command not found"?
Old   March 30, 2016, 15:13
Default How to fix problem with "decomposePar: command not found"?
Tiko
mchehab2 is on a distinguished road
I was trying to apply the solver for K-Epsilon model, and i had this error. can anyone help me with it? Thank you
mchehab2 is offline   Reply With Quote
Old   March 31, 2016, 03:39
akidess's Avatar
Anton Kidess
I recommend reading the user guide. None of your OpenFOAM executables are present. Either you didn't compile properly or you didn't source.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 31, 2016, 07:26
Post
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
you need to decompose your grid before using the parallel mode. Because it requires the decomposed processor directories to start the simulation and i cannot see the processor rank directories in the attached file in your working directory. Make sure that you have the "decomposePar" dictionary in your "system" folder. If not then do that, otherwise you can start the computation in serial mode taking into account the size of your mesh.
good luck
taxalian is offline   Reply With Quote
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
entropy fix for Riemann problem vivek kumar Main CFD Forum 3 August 31, 2005 08:47
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
