March 30, 2016, 05:45 |
Lookup tables
Ali
Rep Power: 13 |
Hi all
I am trying to inject particles using a lookup table. My problem is that if I change the mass flowrate on the lookup table, nothing happens to the results. The solver seems to ignore the lookup table, and use the values in other constant dictionaries. I've tried the tutorial 'cylinder' (reactingParcelFilmFoam) to check that it wasn't just my case, but even when I change the mass flow rate column in that lookup table, the values in the log file don't change. Does anyone have any idea? Both solvers require 'massTotal' in a constant dictionary. If I change this value, the values change in the log file. I've tried to delete this line, however the solver won't run without it. I'm using of 3.0.x for reference. Any help is appreciated! |
March 30, 2016, 09:40 |
Ali
Rep Power: 13 |
So I've figured out that the mass flowrate is calculated from the parameters you give in the 'kinematicCloudProperties' dictionary. It takes massTotal and divides by the duration to get kg/s. This is fine, and may seem obvious, but where I'm getting stuck is finding out what the values of mDot are for in the LookupTable? As far as I can see it makes no difference to the results whatsoever.
I hope this makes my query clearer. |
May 13, 2016, 07:11 |
Ali
Rep Power: 13 |
Hi All
Maybe this should be in the programming section, but I'll ask it here anyway since I've already started a thread. I have a made a kinematicCloudLookupTable which refreshes each timestep. My problem is that the solver does not look at the lookupTable each time step, but rather just takes the first value. Does anyone know how I can force the solver to re-look up the values each time step? The .C files concerned are either InjectionModel.C, or KinematicLookupTableInjetcion.C. I have tried to include some sort of loop in these, (like in the main solver- with pimpleLoop) but with no sucess. Any help would be appreciated. I've been stuck on this for a week now. |
particles lookuptable |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables | Sermengi | OpenFOAM | 2 | December 19, 2014 06:10 |
Convergence on anisotropic tetahedral meshes | pbo | OpenFOAM Running, Solving & CFD | 12 | December 14, 2010 11:59 |
Error with 'vanAlbada' scheme | Julian K. | OpenFOAM Running, Solving & CFD | 0 | June 18, 2009 09:31 |
Buoyancydriven cavity flow | anita | OpenFOAM Running, Solving & CFD | 3 | March 26, 2008 10:24 |
