BrownianMotionForce in "reactingParcelFoam". parcel escaped from inlet and diverged.
Old   March 28, 2016, 10:28
Default BrownianMotionForce in "reactingParcelFoam". parcel escaped from inlet and diverged.
Bijan Darbari
bijan darbari is on a distinguished road
Hello
I'm solving flow and heat transfer of water between two parallel plates with 100 micrometer solid particles (eulerian - lagrangian ).
the flow is laminar. the solver is "reactingParcelFoam".
when the "BrownianMotionForce" activated. many particles escaped from inlet and courantnumber get very high value!!!! so the solver diverged.
the case file attached.
solutionlog:
Create time
Create mesh for time = 5000
Reading g
PIMPLE: Operating solver in PISO mode
Creating combustion model
Selecting combustion model PaSR<rhoChemistryCombustion>
Selecting chemistry type
    chemistrySolver noChemistrySolver;
    chemistryThermo rho;
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         reactingMixture;
    transport       polynomial;
    thermo          hPolynomial;
    energy          sensibleEnthalpy;
    equationOfState icoPolynomial;
    specie          specie;
Selecting chemistryReader foamChemistryReader
chemistryModel: Number of species = 1 and reactions = 0
    using integrated reaction rate
Creating component thermo properties:
    multi-component carrier - 1 species
    liquids - 1 components
    solids - 1 components
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Creating field dpdt
Creating field kinetic energy K
Creating multi-variate interpolation scheme
Selecting radiationModel none
Constructing reacting cloud
Constructing particle forces
    Selecting particle force sphereDrag
    Selecting particle force gravity
    Selecting particle force BrownianMotion
Constructing cloud functions
    Selecting cloud function patchPostProcessing1 of type patchPostProcessing
Constructing particle injection models
Creating injector: model1
Selecting injection model patchInjection
    Constructing 2-D injection
    Choosing nParticle to be a fixed value, massTotal variable now does not determine anything.
Selecting distribution model fixedValue
Selecting dispersion model none
Selecting patch interaction model localInteraction
    Interaction fields will not be written
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Selecting heat transfer model none
Selecting T integration scheme analytical
Selecting composition model singleMixtureFraction
Selecting phase change model none
Selecting devolatilisation model none
Selecting surface reaction model none
No MRF models present
No finite volume options present
Courant Number mean: 0.0512453171 max: 0.1219978729
Starting time loop
faceSource faceSource1:
    total faces  = 40
    total area   = 0.001
    weight field = phi
Time = 5001
Solving 2-D cloud reactingCloud1
Cloud: reactingCloud1 injector: model1
    Added 95 new parcels
    Current number of parcels       = 40
    Current mass in system          = 0.0001675516082
    Linear momentum                 = (-0.0896473776 -0.005854519442 0)
   |Linear momentum|                = 0.08983834208
    Linear kinetic energy           = 1649.634654
    model1:
        number of parcels added     = 95
        mass introduced             = 0.0003979350695
    Parcel fate (number, mass)      : patch frontAndBack
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch top
      - escape                      = 0, 0
      - stick                       = 20, 8.37758041e-05
    Parcel fate (number, mass)      : patch bottom
      - escape                      = 0, 0
      - stick                       = 10, 4.188790205e-05
    Parcel fate (number, mass)      : patch inlet
      - escape                      = 55, 0.0002303834613
      - stick                       = 0, 0
    Parcel fate (number, mass)      : patch outlet
      - escape                      = 0, 0
      - stick                       = 0, 0
    Temperature min/max             = 273, 273
    Mass transfer phase change      = 0
    Mass transfer devolatilisation  = 0
    Mass transfer surface reaction  = 0
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
rho min/max = 999.9999951, 1000.000006
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.9999999582, Final residual = 1.735509726e-07, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.9999999903, Final residual = 1.878729947e-07, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 1, Final residual = 3.671871817e-07, No Iterations 2
T gas min/max   = -5675.506981, 3396.376588
GAMG:  Solving for p, Initial residual = 0.9999999949, Final residual = 0.01993556705, No Iterations 1
rho min/max = -24208271.61, 12617994.23
time step continuity errors : sum local = 300.6960653, global = -3.598339041e-06, cumulative = -3.598339041e-06
p min/max = -94020684.85, 11979377.26
GAMG:  Solving for p, Initial residual = 0.0331384453, Final residual = 0.001899684118, No Iterations 1
rho min/max = -3642313.277, 7998449.618
time step continuity errors : sum local = 59.72799648, global = -8.171689074e-05, cumulative = -8.531522978e-05
p min/max = -93995055.47, 11934471.79
GAMG:  Solving for p, Initial residual = 0.002625535523, Final residual = 6.848064135e-07, No Iterations 7
rho min/max = 823.5085624, 1120.188828
time step continuity errors : sum local = 0.02162576412, global = 0.0003361922804, cumulative = 0.0002508770506
p min/max = -93994845.23, 11910067.61
ExecutionTime = 0.68 s  ClockTime = 0 s
Courant Number mean: 23243.26381 max: 5386047.497
Time = 5002
    Current number of parcels       = 55
    Current mass in system          = 0.0002303834613
    Linear momentum                 = (0.01392251322 -0.01478103055 0)
   |Linear momentum|                = 0.02030554698
    Linear kinetic energy           = 1486.082312
    model1:
        number of parcels added     = 190
        mass introduced             = 0.0007958701389
      - escape                      = 0, 0
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 23, 9.634217471e-05
      - escape                      = 0, 0
      - escape                      = 135, 0.0005654866776
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.5225870011, Final residual = 2.91586547e-07, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.5192037232, Final residual = 5.095801868e-07, No Iterations 5
DILUPBiCG:  Solving for h, Initial residual = 0.9275706068, Final residual = 6.899198912e-08, No Iterations 5
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>]
    in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:?
#3  Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::polynomialTransport<Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > > >::calculate() at ??:?
#4  Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::polynomialTransport<Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > > >::correct() at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
Aborted (core dumped)
bijan@bijan-virtual-machine:~/Desktop/mycase
reactingcloud1properties:
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      reactingCloud1Properties;
solution
    active          true;
    coupled         true;
    transient       yes;
    cellValueSourceCorrection on;
    maxCo           0.1;
    sourceTerms
        schemes
            rho             semiImplicit 1;
            U               semiImplicit 1;
            Yi              semiImplicit 1;
            h               semiImplicit 1;
            radiation       explicit 1;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        thermo:mu       cell;
        T               cell;
        Cp              cell;
        kappa           cell;
        p               cell;
    integrationSchemes
        U               Euler;
        T               analytical;
constantProperties
    rho0            8000;
    T0              273;
    Cp0             710;
    constantVolume  true;
subModels
    particleForces
        sphereDrag;
        gravity;
        BrownianMotion
    lambda     1E-10;
    turbulence false;
    injectionModels
         model1
            type            patchInjection;
            SOI             5000;
            massTotal       0;
            parcelBasisType fixed;
            patchName       inlet;
            duration        10000;
            parcelsPerSecond 95;
            nParticle       1000;
            U0              (0.001 0 0);
            flowRateProfile constant 1;
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   100e-6;
    dispersionModel none;
    patchInteractionModel localInteraction;
    heatTransferModel none;
    compositionModel singleMixtureFraction;
    radiation       off;
    localInteractionCoeffs
        patches
            frontAndBack
                type rebound;
                 e    1;
                mu   0;
            top
                type stick;
            bottom
                type stick;
            inlet
                type escape;
            outlet
                type escape;
    singleMixtureFractionCoeffs
        phases
            gas
            liquid
            solid
            C      1;
        YGasTot0        0;
        YLiquidTot0     0;
        YSolidTot0      1;
cloudFunctions
        type            patchPostProcessing;
        maxStoredParcels 1000000;
        patches         ( outlet );
controldict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     reactingParcelFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         10000;
deltaT          1;
writeControl    adjustableRunTime;
writeInterval  10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  no;
maxCo           6;
maxDeltaT       1;
functions
    faceSource1
        type            faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         yes;
        outputControl   outputTime;
        log             yes;
        valueOutput     no;
        source          patch;
        sourceName      outlet;
        operation       weightedAverage;
        weightField     phi;
        fields
            H2O
            T
fvschemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phid,p)     Gauss upwind;
    div(phi,K)      Gauss upwind;
    div(phi,h)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,omega) Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phi,Yi_h)   Gauss upwind;
laplacianSchemes
    default         Gauss linear uncorrected;
    default         linear;
snGradSchemes
    default         uncorrected;
wallDist
    method meshWave;
fvsolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-05;
        relTol          0.1;
    rhoFinal
        $rho;
        tolerance       1e-05;
        relTol          0;
    "(U|k|omega)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0.1;
    "(U|k|omega)Final"
        $U;
        tolerance       1e-06;
        relTol          0;
    p
        solver          GAMG;
        tolerance       1e-6;
        relTol          0.1;
        smoother        DICGaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    Phi
        $p;
    "(Yi|O2|N2|H2O)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0;
    h
        $Yi;
        relTol          0.1;
    hFinal
        $Yi;
potentialFlow
    // Used for potentialFoam initialisation
    nNonOrthogonalCorrectors 5;
PIMPLE
    transonic       no;
    nOuterCorrectors 1;
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
    momentumPredictor yes;
relaxationFactors
    equations
        ".*"            0.6;
Best wishes.
bijan darbari is offline   Reply With Quote
Old   March 29, 2016, 07:36
Bijan Darbari
hello
I understand that if uncoupled the particles from continuous phase ( set "coupled false;" in "reactingcloud1properties" ) the solution run normally without any divergence.
but It seems that particles aggregated on cell faces when the "brownianmotionforce" activated,
I attached two pictures. in the first picture brownian force activated and in the second, brownian force deactivated. in both cases drag force activated.
what is the problem???
Is it a bug??
Old   June 5, 2016, 04:45
Ping Chang
chpjz0391 is on a distinguished road
Originally Posted by bijan darbari View Post
hello
Is it a bug??
Hi Bijan,
Have you found the answer to your question?
Why that happened? why the particles aggregated on cell faces ?
Regards,
Ping
chpjz0391 is offline   Reply With Quote
Old   June 5, 2016, 05:37
Bijan Darbari
Dear chpjz0391
yes. I solved the problem.
Reduce solution time step in control dict ( may be 1e-6 or 1e-8 ). If the problem don't solved, then type "maxCo 0.05;" at the beginning of "kinematiccloud1properties"( or "reactingcloud1properties" ).
Old   June 7, 2016, 00:29
Ping Chang
Dear chpjz0391
Hi bijian,
Thanks for your reply. It's quite useful. I have another question, do you need to plot the concentration of particles(mg/m3). As I know, this could be achieved by void fraction. I mean void fraction multiply density of particles. However, I can only get the total concentration of particles in this way. If I inject different sized particles in my simulation, how can I get the concentration for each sized particles?
Kind Regards,
Ping
Old   June 7, 2016, 01:00
Bijan Darbari
Dear chpjz0391
Unfortunately I Don't know how to export concentration for each size of particles.
sorry.
Old   June 7, 2016, 02:09
Ping Chang
Dear chpjz0391
sorry.
Dear bijian,
It's ok. Actually I am using the simpleReactingParcel to simulate the lagrangian particles for steady-state. I met the same problems as yours. Particles aggregated on cell faces. Do you have any suggestion?
Kind Regards,
Ping
Old   June 7, 2016, 03:47
Ping Chang
Originally Posted by chpjz0391 View Post
Dear bijian,
It's ok. Last time you told me ,reactingParcelFoam can simulation collisions between particles. But when I try to add collisionModel in reactingCloud1Properties. It does not work.
Hi bijian,
I have found that function, stochasticCollisionModel is used to simulate collision between particles.
Cheers.
Ping
