March 24, 2016, 12:13 |
Zero result in coefficients
Justin Maris L. Natividad
Rep Power: 10 |
Hi there. I am currently using OpenFoam, which is new to me. Now I am trying to solve a case using simpleFoam. I already have meshed my model using snappyHExMesh (although I am not sure if it is right, but the checkMesh says its ok). Then I used the system files from the motorbike tutorial, and edited the files from the 0 files, since the solver is looking for the top and bottom part. Then luckily the solver run, but after that, there is no results, and when I run paraview, there is no result of p nor U. How can I fix this? Thank you for the consideration Attached is the result of the solver,
March 24, 2016, 13:51 |
Vinícius da Costa Ávila
Rep Power: 11 |
Hi, have you edited the 0 folder files how? could you post them here?
Isn't there folders for each timeStep on the case main folder? If so, the files for U and p aren't in there? could you post a print of the main folder and of a timeStep (10, for example) folder? The reason I ask is to try to understand if your problem is about the files generation or the paraView exhibition.
Vinícius dC.A. |
March 26, 2016, 04:52 |
Rep Power: 10 |
Hello, sorry for the late reply. Attached are the images for the main folder, and for each timestep. There are the directories of the p and U for each timestep. Thank you
Arrhenius coefficients for methane air single step combustion | a.Asadi | OpenFOAM Pre-Processing | 0 | August 20, 2015 03:43 |
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 | wan11 | CFX | 3 | December 18, 2014 19:25 |
Question on running CFX simulations in workbench parameter set table | Anna Tian | CFX | 0 | September 20, 2014 01:51 |
Result output chart | YaX | CFX | 4 | July 10, 2014 18:47 |
tube bank inertial resistance coefficients | Brian | FLUENT | 0 | September 8, 2004 09:04 |
