March 23, 2016, 15:35 |
OpenFoam with PBS job manager
Rep Power: 10 |
Is there any official tutorial or example regarding OpenFoam and PBS job scheduler (the qsub command)? I saw some pages on the web but it seems that they are trying to show how to solve a problem first.
I actually don't care about that since my job is to install (have already done) and check it users can submit their jobs to the cluster. So, I need an example which shows how to submit a solved problem (meshing, ...) to the job scheduler. Basically, I write a pbs script and put "ls" command in it and submit it to the scheduler to see if all nodes are working and communicating. So, I am searching for a similar simple command with respect to OpenFoam. Any idea for that? |
March 23, 2016, 22:40 |
Weiwen Zhao
Rep Power: 13 |
Hi mahmoodn,
You can use blockMesh and snappyHexMesh provided by OpenFOAM for meshing. For testing PBS job scheduler, you can simply pick up a tutorial case from $FOAM_TUTORIALS directory and test with that case. The $FOAM_TUTORIALS/incompressible/icoFoam/cavity is a good start. You need to copy it to your working directory, and run blockMesh inside the case directory. After meshing is done, run icoFoam to begin your simulation. P.S.: don't forget to source OpenFOAM bashrc first |
March 24, 2016, 02:24 |
Rep Power: 10 |
Do you have any idea about this:
mahmood@cluster:of-test$ source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc mahmood@cluster:of-test$ blockMesh -bash: blockMesh: command not found mahmood@cluster:of-test$ /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64Gcc48DPOpt/bin/blockMesh /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64Gcc48DPOpt/bin/blockMesh: error while loading shared libraries: libblockMesh.so: cannot open shared object file: No such file or directory mahmood@cluster:of-test$ |
March 24, 2016, 11:02 |
Weiwen Zhao
Rep Power: 13 |
Hi mahmoodn,
Have you modified the bashrc from OpenFOAM? What's the value of your $FOAM_INST_DIR and $WM_PROJECT_INST_DIR? |
March 24, 2016, 11:11 |
Rep Power: 10 |
Yes, I modified it during the installation. Lines associated with that is
export WM_PROJECT=OpenFOAM export WM_PROJECT_VERSION=2.3.0 foamInstall=/export/apps/mechanics/$WM_PROJECT Code:
$ ls /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/ Allwmake bin doc platforms README.org tutorials applications COPYING etc README.html src wmake Code:
$ echo $FOAM_INST_DIR /export/apps/mechanics/OpenFOAM $ echo $WM_PROJECT_INST_DIR /export/apps/mechanics/OpenFOAM |
March 24, 2016, 11:43 |
Weiwen Zhao
Rep Power: 13 |
Hmm. Seems the shell variables aren't exported correctly.
What's the output of export | grep -E '(FOAM_|WM_)'? What's the value of your $PATH and $LD_LIBRARY_PATH? |
March 24, 2016, 13:11 |
Rep Power: 10 |
Check it
$ export | grep -E '(FOAM_|WM_)' declare -x FOAM_APP="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/applications" declare -x FOAM_APPBIN="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin" declare -x FOAM_EXT_LIBBIN="/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib" declare -x FOAM_INST_DIR="/export/apps/mechanics/OpenFOAM" declare -x FOAM_JOB_DIR="/export/apps/mechanics/OpenFOAM/jobControl" declare -x FOAM_LIBBIN="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib" declare -x FOAM_MPI="openmpi-1.6.5" declare -x FOAM_RUN="/home/mahmood/OpenFOAM/mahmood-2.3.0/run" declare -x FOAM_SETTINGS="" declare -x FOAM_SIGFPE="" declare -x FOAM_SITE_APPBIN="/export/apps/mechanics/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/bin" declare -x FOAM_SITE_LIBBIN="/export/apps/mechanics/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/lib" declare -x FOAM_SOLVERS="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/applications/solvers" declare -x FOAM_SRC="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/src" declare -x FOAM_TUTORIALS="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/tutorials" declare -x FOAM_USER_APPBIN="/home/mahmood/OpenFOAM/mahmood-2.3.0/platforms/linux64GccDPOpt/bin" declare -x FOAM_USER_LIBBIN="/home/mahmood/OpenFOAM/mahmood-2.3.0/platforms/linux64GccDPOpt/lib" declare -x FOAM_UTILITIES="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/applications/utilities" declare -x WM_ARCH="linux64" declare -x WM_ARCH_OPTION="64" declare -x WM_CC="gcc" declare -x WM_CFLAGS="-m64 -fPIC" declare -x WM_COMPILER="Gcc" declare -x WM_COMPILER_LIB_ARCH="64" declare -x WM_COMPILE_OPTION="Opt" declare -x WM_CXX="g++" declare -x WM_CXXFLAGS="-m64 -fPIC" declare -x WM_DIR="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/wmake" declare -x WM_LDFLAGS="-m64" declare -x WM_LINK_LANGUAGE="c++" declare -x WM_MPLIB="OPENMPI" declare -x WM_OPTIONS="linux64GccDPOpt" declare -x WM_OSTYPE="POSIX" declare -x WM_PRECISION_OPTION="DP" declare -x WM_PROJECT="OpenFOAM" declare -x WM_PROJECT_DIR="/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0" declare -x WM_PROJECT_INST_DIR="/export/apps/mechanics/OpenFOAM" declare -x WM_PROJECT_USER_DIR="/home/mahmood/OpenFOAM/mahmood-2.3.0" declare -x WM_PROJECT_VERSION="2.3.0" declare -x WM_THIRD_PARTY_DIR="/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0" $ echo $PATH /export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/gperftools-svn/bin:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/bin:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/bin:/home/mahmood/OpenFOAM/mahmood-2.3.0/platforms/linux64GccDPOpt/bin:/export/apps/mechanics/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/bin:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/bin:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/wmake:/opt/openmpi/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/bio/ncbi/bin:/opt/bio/mpiblast/bin:/opt/bio/EMBOSS/bin:/opt/bio/clustalw/bin:/opt/bio/tcoffee/bin:/opt/bio/hmmer/bin:/opt/bio/phylip/exe:/opt/bio/mrbayes:/opt/bio/fasta:/opt/bio/glimmer/bin:/opt/bio/glimmer/scripts:/opt/bio/gromacs/bin:/opt/bio/gmap/bin:/opt/bio/tigr/bin:/opt/bio/autodocksuite/bin:/opt/bio/wgs/bin:/opt/eclipse:/opt/ganglia/bin:/opt/ganglia/sbin:/usr/java/latest/bin:/opt/maven/bin:/opt/maui/bin:/opt/torque/bin:/opt/torque/sbin:/opt/pdsh/bin:/opt/rocks/bin:/opt/rocks/sbin:/opt/condor/bin:/opt/condor/sbin:/opt/gridengine/bin/linux-x64:/export/apps/mathematics/matlab2012a/bin:/home/mahmood/bin $ echo $LD_LIBRARY_PATH /export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/gperftools-svn/lib:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/lib/paraview-4.1:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/openmpi-1.6.5:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib/openmpi-1.6.5:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/lib:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/openmpi-1.6.5/lib64:/home/mahmood/OpenFOAM/mahmood-2.3.0/platforms/linux64GccDPOpt/lib:/export/apps/mechanics/OpenFOAM/site/2.3.0/platforms/linux64GccDPOpt/lib:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib:/export/apps/mechanics/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib:/export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/dummy:/opt/gridengine/lib/linux-x64:/opt/openmpi/lib |
March 24, 2016, 19:21 |
Weiwen Zhao
Rep Power: 13 |
Seems your applications aren't installed to $FOAM_APPBIN.
Have you exported WM_COMPILER=Gcc48 before building OpenFOAM? This may be the issue. If so, just rebuild OpenFOAM without exporting that. |
March 25, 2016, 02:37 |
#9 |
Rep Power: 10 |
I ran it again. Please see the variables first
root@cluster:ThirdParty-2.3.0# module load openmpi-x86_64 || export PATH=$PATH:/usr/lib64/openmpi/bin root@cluster:ThirdParty-2.3.0# source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI root@cluster:ThirdParty-2.3.0# root@cluster:OpenFOAM-2.3.0# echo $WM_NCOMPPROCS 4 root@cluster:OpenFOAM-2.3.0# echo $WM_COMPILER Gcc48 root@cluster:OpenFOAM-2.3.0# echo $WM_MPLIB SYSTEMOPENMPI root@cluster:OpenFOAM-2.3.0# echo $FOAM_APPBIN /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64Gcc48DPOpt/bin This time, when I run blockMesh, I see its usage Code:
root@cluster:OpenFOAM-2.3.0# blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : blockMesh Date : Mar 25 2016 Time : 11:03:08 Host : "cluster.scu.ac.ir" PID : 10972 Case : /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Question: What commands should I put in the .bashrc or /etc/profile (for all users)? These two? Code:
root@cluster:ThirdParty-2.3.0# module load openmpi-x86_64 || export PATH=$PATH:/usr/lib64/openmpi/bin root@cluster:ThirdParty-2.3.0# source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI |
March 25, 2016, 03:39 |
#10 | |
Weiwen Zhao
Rep Power: 13 |
Hi mahmoodn,
Good to see it working Quote:
Just keep the user variables same with those when you built OpenFOAM . Regards, Weiwen |
March 25, 2016, 03:56 |
#11 |
Rep Power: 10 |
It seems that the following line has no effect in /etc/profile and ~/.bashrc
alias of230='module load openmpi-x86_64; source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' Code:
March 25, 2016, 04:01 |
#12 | |
Weiwen Zhao
Rep Power: 13 |
alias of230='module load openmpi-x86_64; source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' The aliases are useful when there are multiple OpenFOAM versions as it wouldn't mess up the environment variables . Regards, Weiwen |
March 25, 2016, 04:03 |
#13 |
Rep Power: 10 |
OK I got it... So the correct thing is to first run of230 and then blockMesh.
Thanks for that. I will move on to the tutorial for PBS. |
March 25, 2016, 05:58 |
#14 |
Rep Power: 10 |
Hi again,
I ran blockMesh and then icoFoam in the $FOAM_TUTORIALS/incompressible/icoFoam/cavity. I saw some outputs without any error and it seems it is working. Is there any multithreaded (needing more than core) example which I want to test with PBS? |
March 25, 2016, 07:00 |
#15 | |
Weiwen Zhao
Rep Power: 13 |
The following steps may be helpful. 1. Copy the propeller case to your working directory. 2. Run ./Allrun.pre to generate mesh and set initial conditions. 3. Run decomposePar to decompose the domain into 4 parts. 4. Prepare the PBS submit scripts. A simple example may look like this: Code:
#!/bin/bash #PBS -l nodes=1:ppn=4 # #PBS -l walltime=00:30:00 #PBS -N myJobName #PBS -A MyProjectName #PBS -o outputFileName #PBS -e errorFileName module load openmpi-x86_64 source /export/apps/mechanics/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI mpirun -np 4 pimpleDyMFoam -parallel | tee log Regards, Weiwen |
March 25, 2016, 11:58 |
#16 |
Rep Power: 10 |
Some good news and some bad news...
Good: I am able to run the mpi command on master node as well as the compute node. In other words, the following commands works as expected. Code:
of230 mpirun -np 4 pimpleDyMFoam -parallel | tee log However, when I submit the job, the output file contains the following error: Code:
mahmood@cluster:propeller$ qsub submit.tor 49.cluster.scu mahmood@cluster:propeller$ qstat Job id Name User Time Use S Queue ------------------------- ---------------- --------------- -------- - ----- 49.cluster myJobName mahmood 0 R default mahmood@cluster:propeller$ qstat Job id Name User Time Use S Queue ------------------------- ---------------- --------------- -------- - ----- 49.cluster myJobName mahmood 00:00:00 C default mahmood@cluster:propeller$ cat outputFileName /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : pimpleDyMFoam -parallel Date : Mar 25 2016 Time : 20:20:19 Host : "compute-0-0.local" PID : 2102 [0] [0] [0] --> FOAM FATAL ERROR: [0] Cannot read "/home/mahmood/system/decomposeParDict" [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 2102 on node compute-0-0.local exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- |
March 25, 2016, 13:30 |
#17 |
Rep Power: 10 |
Regarding the error
Cannot read "/home/mahmood/system/decomposeParDict" Code:
mahmood@cluster:propeller$ pwd /home/mahmood/of-test/propeller mahmood@cluster:propeller$ ls 0 Allrun.pre log.createPatch log.topoSet processor1 system 0.org constant log.renumberMesh outputFileName processor2 Allclean log log.snappyHexMesh postProcessing processor3 Allrun log.blockMesh log.surfaceFeatureExtract processor0 submit.tor mahmood@cluster:propeller$ ls system/ controlDict forces readFields surfaces createInletOutletSets.topoSetDict fvSchemes snappyHexMeshDict createPatchDict fvSolution surfaceFeatureExtractDict decomposeParDict Q surfaceFeatureExtractDictDefaults Any idea for that? |
March 25, 2016, 13:36 |
#18 |
Rep Power: 10 |
OK. I think I found the problem. According to Basics: Set-up for different desktop machines (post #7 and after that), I found that my home has not been exported to the NFS! (have to say that I created my account on the server only).
So, let me test something and I will be back. |
March 25, 2016, 14:16 |
#19 |
Weiwen Zhao
Rep Power: 13 |
Hi mahmoodn,
You need to setup NIS server and client for sharing account info. Moreover, the home of compute nodes should be mounted via NFS. Regards, Weiwen |
March 25, 2016, 15:53 |
#20 |
Rep Power: 10 |
OK I found the problem
In the PBS script, we have to add cd $PBS_O_WORKDIR abd this is an important thing. Without that and by adding pwd before the mpi command in the PBS script, I saw that the working directory was /home/mahmood which is actually $HOME and for that reason it appended system/decomposeParDict to that. With cd $PBS_O_WORKDIR, the working directory is correctly set to the location where propeller exists. So, everything is OK now and I am able to run a OpenFoam job. Have to tell the guys for that. Thanks. |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 14:43 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
cfd job | Dr. Don I anyanwu | Main CFD Forum | 20 | May 17, 1999 16:13 |
