Parallel Processisng DecomposePAR - Different Solutions
Old   March 23, 2016, 08:22
Default Parallel Processisng DecomposePAR - Different Solutions
Peter Hagan
PeteH is on a distinguished road
I am trying to understand the time and solution effects of parallel processing on my computer (i7 mac running CAElinux 2013). I had a case that I've been trying to run on 4 cores (76000 cells on each decomposed mesh part - too many?) and I found that the parallel processing did not speed it up at all. So, experiment:
I ran the Tjunction case in the incompressable tutorial folder as a serial solver and it finished in 15 seconds.
I then decomposed it into (4 1 1) using 4 cores, used the renumberMesh utility and ran it again as a parallel process. This time it took 20 seconds. I can understand that because the geometry would bottleneck the solution at the end of the geometry in addition to the wasted time talking with so many cores for a small simulation.
So I decomposed the geometry into (1 2 1) using 2 cores, renumberMesh, and ran again. This time it finished in 12 seconds. This also made sense to me because now it is splitting the geometry symmetrically along the x axis and for such a small case, it should help.
The only problem I see now, is that the solution when looking in ParaView is very different from the serial solution. any ideas why this would be the case?
Also, I get a random .001 time step folder in the case folder. All other time steps are located in the processor 0 or processor 1 folders except for the IC 0 folder. Any ideas why that is there?
PeteH is offline   Reply With Quote
Old   March 24, 2016, 08:25
Peter Hagan
I figured it out.
I was performing the reconstructPar incorrectly. The Tjunction case works correctly, now.
As for my other case -
Split into 4 partitions (76000 cells each) with 4 cores, I am not seeing a decreased solving time.
Could this be a RAM issue?
I will try to decrease the number of cells to about 200k total - about 50k per partition, and see how that affects the speed.
Any thoughts are appreciated.
Running decomposePar / reconstructPar as parallel apps? carcass OpenFOAM Running, Solving & CFD 3 January 17, 2024 08:19
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
decomposePar: "Couldn't create directory" Manm OpenFOAM Pre-Processing 1 April 19, 2015 12:28
how to make parallel running? decomposePar. panda60 OpenFOAM 1 October 29, 2009 03:43
