Parallel processing, processors weirdly utilized
Old   March 22, 2016, 10:00
Default Parallel processing, processors weirdly utilized
wannab_phd is on a distinguished road
Hello, I'm fairly new to OpenFOAM, but have decided today to run a small 2D case of flow around a cylinder, I failed, but that has another reason. The thing is, I ran it with multiple processors, I have an i5 4210H, dual core, but actually 4 cores, right, and I pulled that decomposeParDict, and specified the division of my domain to (2 2 1), z iz my empty direction. Weird thing happened, as I thought my processors would wind up to 99-100%, and the case would be solved in minutes. They instead acted like this:
http://s9.postimg.org/oykr1t4gf/parallel1.png
http://s22.postimg.org/9lgvo4ntd/parallel2.png
Iterations ran in terminal when all 4 processors were fully engaged, and then pause, nothing crashed, it wasn't a crash. The PC responded, and Terminal also responded, it just paused... Then continued to another peak, and paused again. Pauses were irregular.
Can someone explain that? Because I can't.
Thanks!
wannab_phd is offline   Reply With Quote
Old   March 23, 2016, 05:34
chriss85 will become famous soon enough
Do they have a similar amount of cells and shared faces? It is also advised to run the renumberMesh utility for some speedup due to optimized caching. The latter point is probably not related to your issue though.
chriss85 is offline   Reply With Quote
Old   March 23, 2016, 06:16
I don't know if they have a similar amount of cells and shared faces. How do I check that? Better yet, how do I make it similar? I will try the renumberMesh, thanks!
Old   March 23, 2016, 06:47
Antimony is on a distinguished road
You can take a look at the log file from decomposePar to see the distribution per processor.
To do a better load balance, you could use scotch as the method instead of simple/hierarchical. You don't need to define any coefficients as the code looks at the mesh and partitions it in the way it thinks is best.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 23, 2016, 08:16
Will do! BTW does it (can it) matter if it's all ran from a live USB stick?
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 20, 2015 00:41
OF Parallel Processing with Core i7 - How to Handle Hyperthreading dancfd OpenFOAM Running, Solving & CFD 5 March 5, 2012 22:43
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 16:54
