Reconstructing Error
Old   March 17, 2016, 01:56
Unhappy Reconstructing Error
Mohsen
mohsen.boojari is on a distinguished road
I have done a simulation and completed it successfully. after the solver done it's job I run the ReconstructParMesh and it's done too. But when I tried to do ReconstructPar i got the error below. can anybody help me??
thanks
Create time
Reconstructing fields for mesh region0
Time = constant
Reconstructing FV fields
No FV fields
Reconstructing point fields
No point fields
No lagrangian fields
Time = 0.015
    Reconstructing volScalarFields
        nuSgs
--> FOAM FATAL ERROR:
Attempt to cast type processor to type processorCyclic
    From function refCast<To>(From&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
mohsen.boojari is offline   Reply With Quote
Old   June 26, 2022, 02:39
Default Hi,Mohsen, I meet the Same issue with reconstructPar, did you get your issue solved?
Yi Han
hy1112006 is on a distinguished road
Hi,Mohsen, I meet the Same issue with reconstructPar, did you get your issue solved? If did, would you please post the solution, thanks so much!
Originally Posted by mohsen.boojari View Post
thanks
Create time
Time = constant
No FV fields
No point fields
Time = 0.015
        nuSgs
FOAM aborting
hy1112006 is offline   Reply With Quote
cyclic, error, processor, reconstuctpar
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
