Why does potentialFoam not accept a region input? |
March 12, 2016, 05:44 |
Rep Power: 15 |
I'm using a modified potentialFoam to initialize a large case with two fluid regions.The original potentialFoam doesn't accept a -region option, so I had to add that. Why does it not? Is there a simple reason for this or is the solver just so basic that the OF crew thought "well if people use chtMultiRegionSimpleFoam, they'll know how to adapt potentialFoam to their needs"?
Modifying (in OF 2.3.1 ) potentialFoam to accept a -region option was trivial, though. Regards Christoph |
August 25, 2016, 07:04 |
#2 | |
Tung
I am interested in your modified potentialFoam because I also need a solver like that. Could you share it here? I would be very grateful if you do that. Best regard, Huynh |
October 26, 2016, 04:52 |
carno
Rep Power: 17 |
I also have the same problem. How/what to modify potentialFoam to read region?
multiregion, potentialfoam |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation | Zeppo | OpenFOAM Running, Solving & CFD | 16 | May 18, 2017 19:04 |
Floating Point Error with kOmegaSST Turbulence Model | shipman | OpenFOAM Running, Solving & CFD | 5 | January 4, 2016 09:57 |
Porous Region within Open Air "Wind Tunnel" Region Interfacing | pkirchner | STAR-CCM+ | 10 | March 27, 2014 20:10 |
