Inlet Turbulence parameters k/omega by timeVarying Velocity
Old   March 11, 2016, 08:35
Default Inlet Turbulence parameters k/omega by timeVarying Velocity
Stefan
StefanW is on a distinguished road
Dear Formers,
i got a transient RANS model which needs a timeVarying Inlet-Velocity (Valve open/close)
It varies between 0 and 4 m/s. (arranged with timeVaryingUniformFixedValue and a txt file)
My question is now according the turbulence parameters k and omega (k-w-sst-Model)? What is the best type of Inlet BC therefore? I had the following thoughts:
If I calculate and implement fixedValues at the inlet it is fixed for all the simulation time what is not really true because the velocity and so k (=1.5*(U*I)^2 changes over the time. That may leeds to convergence problems???
The other option is to use turbulenceIntensityKineticEnergieInlet for k and defining an Intensity. But here I got bad feelings according the case if U=0 so k=0 and there might show up an dividing /0
Same for omega with turbulentMixingLengthFrequency.
What is the most stable definition?
Would be greate if somebody could help me out!
Thank you in advance
Stefan
StefanW is offline   Reply With Quote
Old   March 11, 2016, 08:36
Stefan
Another idea:
Would it make sense to make timedependendValue-Files for k and omega
like as for the velocity?
Old   March 11, 2016, 16:03
Eric Robertson
msuaeronautics is on a distinguished road
Originally Posted by StefanW View Post
Another idea:
You probably should vary the freestream turbulence parameters along with the velocity. Though you only ramp up the inflow velocity by a small amount, there is of course much evidence that your choice of freestream turbulence parameters affect the solution. So, what you choose to do actually depends on what you're looking to accomplish.
msuaeronautics is offline   Reply With Quote
k-omega, k-w-sst, omega, rans modelling, turbulence parameters
possible to have a controller on inlet turbulence intensity? mrshives CFX 6 February 2, 2016 18:55
Patch fully developed velocity and turbulence profile over full domain Teumde FLUENT 2 June 29, 2015 14:47
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 06:17
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 05:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
