Unknown Error while using PisoFoam
Old   March 10, 2016, 04:23
Red face Unknown Error while using PisoFoam
Mohsen
mohsen.boojari is on a distinguished road
I was running a simulation case and after 2nd iteration i got this Message in my Solver.log Script. can anyone help me what's wrong with my case?
thank you
Create time
Create mesh for time = 0
Reading field, p...
Reading field, U...
Creating vorticity field, omega...
Creating second-invariant of strain-rate tensor field, Q...
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model Smagorinsky
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
SmagorinskyCoeffs
    ce              0.93;
    ck              0.033647;
Thrust from Body Force = 1713.97835358	Thrust from Act. Line = 1727.88845451	Ratio = 0.991949653405
Torque from Body Force = 452.118249792	Torque from Act. Line = 455.859243184	Ratio = 0.991793533973
Creating time-average velocity field, UMean...
Creating time-averaged pressure field, pMean...
Creating the time-averaged velocity correlation field (<u_i'u_j'>), uuMean...
Creating the time-averaged pressure correlation field (<p'p'>), ppMean...
Creating the time-averaged velocity-pressure correlation field (<u_i'p'>), upMean...
Creating the time-averaged modeled turbulent stress field (<R_ij>), RMean...
Creating the time-averaged modeled turbulent kinetic energy field (<k>), kMean...
Creating the time-averaged modeled turbulent stress field (<u_i'u_j'> + <R_ij>), uuRTotal...
Creating divergence scheme blending factor field, UBlendingFactor...
Starting time loop
Time = 0.00015
Courant Number mean: 0.0124791666668 max: 0.0125
DILUPBiCG:  Solving for Ux, Initial residual = 0.999999999995, Final residual = 2.83159674539e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 4.61367500519e-14, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 5.13272601867e-14, No Iterations 3
mpirun noticed that process rank 5 with PID 7216 on node mohsen-Lenovo-G580 exited on signal 9 (Killed).
mohsen.boojari is offline   Reply With Quote
Old   March 10, 2016, 06:06
Alex
Kina is on a distinguished road
Can you run the case without mpi?
Kina is offline   Reply With Quote
Old   March 10, 2016, 10:59
Mohsen
I tried, But nothing changed !!
Old   April 28, 2018, 00:21
Scram_1 is on a distinguished road
Hey,
Did you find a work around to your problem?
Best,
Scram_1
Scram_1 is offline   Reply With Quote
Old   April 29, 2018, 03:05
JD
dickcruz is on a distinguished road
What does the output look like?
dickcruz is offline   Reply With Quote
mpirun error, pisofoam, solver
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
Thermal Comfort Simulation in STAR CCM+ anupmu STAR-CCM+ 1 February 27, 2013 15:25
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
