Segmentation fault in layerAdditionRemoval Foam-extend 3.1 |
March 9, 2016, 13:30 |
Joao Bettencourt
Rep Power: 10 |
Dear all,
I am testing a model of a heaving disk in waves using GGI interfaces and layer addition removal, similar to the moving cylinders case that is distributed in the tutorial. I am testing the mesh motion with the moveDynamicMesh utility and I am getting a segmentation fault on the first layer addition event. The original mesh in the layer addition/removal cell zones is rectangular with cell thickness in the direction of the motion of 0.01. The layer removal threshold is 0.005 and the addition threshold is 0.015. I am animating the mesh with an oscillating motion defined by: Code:
solidBodyMotionFunction linearOscillation; linearOscillationCoeffs { amplitude (0 0 0.08); period 2; } Mesh Courant Number mean: 0.00136134113 max: 0.865961662 The output at the moment of the crash and at the previous time step is the following: Code:
Time = 0.0202 bool layerAdditionRemoval::changeTopology() const for object topLayerDiskLayerHeavingDisk : Layer thickness: min: 0.01490439482 max: 0.01490439482 avg: 0.01490439482 old thickness: 1e+15 Removal threshold: 0.005 addition threshold: 0.015 Modifier 0 named topLayerDiskLayerHeavingDisk unchanged bool layerAdditionRemoval::changeTopology() const for object botLayerDiskLayerHeavingDisk : Layer thickness: min: 0.01499046168 max: 0.01499046168 avg: 0.01499046168 old thickness: 0.01494029638 Removal threshold: 0.005 addition threshold: 0.015 Modifier 1 named botLayerDiskLayerHeavingDisk unchanged Local mesh update: 0 global update: 0 Executing mesh motion volume continuity errors : volume = 6.285, old volume = 6.285, max error = 5.973089608e-13, sum local = 6.372386702e-20, global = 5.531128242e-24 Mesh Courant Number mean: 0.00136134113 max: 0.865961662 Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Mesh topology OK. Boundary openness (1.708629482e-17 -2.389890301e-18 1.256910151e-16) Threshold = 1e-06 OK. Max cell openness = 2.186977911e-16 OK. Max aspect ratio = 887.4390306 OK. Minumum face area = 2.317114e-07. Maximum face area = 0.001605357027. Face area magnitudes OK. Min volume = 2.317114e-08. Max volume = 1.504062498e-05. Total volume = 6.285. Cell volumes OK. Mesh non-orthogonality Max: 28.30781727 average: 1.558811389 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.497720423 OK. Mesh geometry OK. Mesh OK. ExecutionTime = 505.64 s ClockTime = 506 s Time = 0.0204 bool layerAdditionRemoval::changeTopology() const for object topLayerDiskLayerHeavingDisk : Layer thickness: min: 0.01485423152 max: 0.01485423152 avg: 0.01485423152 old thickness: 0.01490439482 Removal threshold: 0.005 addition threshold: 0.015 Modifier 0 named topLayerDiskLayerHeavingDisk unchanged bool layerAdditionRemoval::changeTopology() const for object botLayerDiskLayerHeavingDisk : Layer thickness: min: 0.01504062498 max: 0.01504062498 avg: 0.01504062498 old thickness: 0.01499046168 Removal threshold: 0.005 addition threshold: 0.015 bool layerAdditionRemoval::changeTopology() const for object botLayerDiskLayerHeavingDisk : Triggering layer addition Modifier 1 named botLayerDiskLayerHeavingDisk morphing Local mesh update: 1 global update: 1 void layerAdditionRemoval::addCellLayer(polyTopoChange& ref) const for object botLayerDiskLayerHeavingDisk : Adding cell layer void layerAdditionRemoval::addCellLayer(polyTopoChange& ref) const for object botLayerDiskLayerHeavingDisk : Using edges for point insertion void layerAdditionRemoval::addCellLayer(polyTopoChange& ref) const for object botLayerDiskLayerHeavingDisk : Finished adding cell layer layerAdditionRemoval::setRefinement(polyTopoChange& ref) for object botLayerDiskLayerHeavingDisk : Clearing addressing after layer addition. polyTopoChanger::changeMesh ( const polyTopoChange& ref ) : started executing topological change. Added untouched points. Point count = 1044606 Added live points: modified = 0 added = 1002. Point count = 1045608 Added retired points: modified = 0 added = 0. Point count = 1045608 Added all points. Final point count = 1045608 Inserted untouched faces into cells Inserted modified faces into cells Inserted added faces into cells Added internal faces. Face count = 1077764 Patch 0: added faces: untouched = 292 modified = 0 added = 0. Face count = 1078056 Patch 1: added faces: untouched = 292 modified = 0 added = 0. Face count = 1078348 Patch 2: added faces: untouched = 292 modified = 0 added = 0. Face count = 1078640 Patch 3: added faces: untouched = 292 modified = 0 added = 0. Face count = 1078932 Patch 4: added faces: untouched = 1150 modified = 0 added = 0. Face count = 1080082 Patch 5: added faces: untouched = 1118292 modified = 1000 added = 1000. Face count = 2200374 Patch 6: added faces: untouched = 349 modified = 1 added = 1. Face count = 2200725 Patch 7: added faces: untouched = 349 modified = 1 added = 1. Face count = 2201076 Patch 8: added faces: untouched = 1584 modified = 0 added = 0. Face count = 2202660 triangular element zone. This zone slides along the quad zone to the left of the picture and the layer addition occurs in the quad zone below the tri zone. A backtrace from the crash is below Code:
*** Error in `moveDynamicMesh': free(): invalid pointer: 0x00000000017f5002 *** ======= Backtrace: ========= /lib64/libc.so.6(+0x7d023)[0x7fd1b6b83023] /home/jbettencourt/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListIiEaSERKS1_+0x29)[0x7fd1ba3f1899] /home/jbettencourt/foam/foam-extend-3.1/lib/linux64GccDPOpt/libdynamicMesh.so(_ZN4Foam15polyTopoChanger10changeMeshERNS_8polyMeshERKNS_14polyTopoChangeE+0x138f)[0x7fd1b91dec0f] /home/jbettencourt/foam/foam-extend-3.1/lib/linux64GccDPOpt/libdynamicMesh.so(_ZN4Foam15polyTopoChanger10changeMeshEv+0x367)[0x7fd1b91e5927] /home/jbettencourt/foam/foam-extend-3.1/lib/linux64GccDPOpt/libtopoChangerFvMesh.so(_ZN4Foam19multiTopoBodyFvMesh6updateEv+0x16b)[0x7fd1b495fbab] moveDynamicMesh[0x40d887] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fd1b6b27b15] moveDynamicMesh[0x40e975] ======= Memory map: ======== Thanks, Joao |
March 9, 2016, 13:40 |
Additional information on the subject above
Joao Bettencourt
Rep Power: 10 |
Dear all,
I have run the problem use a debug version of foam-extend 3.1 and got this additional message: Code:
--> FOAM FATAL ERROR: index 2205745 out of range 0 ... 2205744 From function UList<T>::checkIndex(const label) in file /home/jbettencourt/foam-debug/foam-extend-3.1/src/foam/lnInclude/UListI.H at line 124. FOAM aborting Kind regards, Joao |
March 9, 2016, 15:22 |
Rep Power: 21 |
Just to check. The orientation of the faceZone is correct? Try inverting it and check directly in the faceZone file.
March 10, 2016, 05:53 |
#4 | |
Joao Bettencourt
Rep Power: 10 |
cellSet Disk new boxToCell (6.5 0 -0.475) (11.5 0.1 0.125) cellSet TopDisk new boxToCell (6.5 0 0.125) (11.5 0.1 1.5) cellSet BotDisk new boxToCell (6.5 0 -2) (11.5 0.1 -0.475) faceSet topLayerDisk new cellToFace Disk all faceSet topLayerDisk subset cellToFace TopDisk all cellSet topLayerDiskMasterCells new cellToCell TopDisk faceSet botLayerDisk new cellToFace Disk all faceSet botLayerDisk subset cellToFace BotDisk all cellSet botLayerDiskMasterCells new cellToCell BotDisk cellSet TopDisk delete cellSet BotDisk delete Here's the thing: I have the model working now, it seems. The problem, as far as I can tell was that after this operation I wasn't deleting the TopDisk and BotDisk cell Sets. Now that I've added Code:
cellSet TopDisk delete cellSet BotDisk delete So the origin of the problem seemed to be these additional cell sets that were not being deleted and causing some kind of repeated operation in the same face. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
