Pressure in solidDisplacementFoam
Old   March 7, 2016, 15:44
Default Pressure in solidDisplacementFoam
Ruggero Poletto
rupole1185 is on a distinguished road
Is it correct this in the D file:
wall_name
type tractionDisplacement;
traction uniform ( 0 0 0 );
pressure uniform 600000;
value uniform (0 0 0);
Application of the pressure that act of a particular wall?
rupole1185 is offline   Reply With Quote
Old   March 8, 2016, 06:52
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
wall_name
Yes, this will apply a surface pressure of 0.6 MPa to the wall.
The surface pressure is: Tn = -n & (n & sigma),
where 'n' is the surface unit normals and 'sigma' is the stress tensor.
Philip
bigphil is offline   Reply With Quote
Old   March 8, 2016, 08:25
Ruggero Poletto
Thanks a lot for your reply!
___________________________
President of CONSELF, the new CFD company with a great cloud solution. Try for free it here!
Old   October 15, 2016, 16:48
Default tractionDisplacement | meaning of "value (0 0 0)"?
tomdylan's Avatar
Tom Dylan
tomdylan is on a distinguished road
Philip
Could you kindly explain the third parameter vector "value (0 0 0)"?
Does it have to do something with a pressure gradient?
My problem consists of pressure variations on a vertical (or inclined) wall in response to water level fluctuations. In that case the pressure has a hydrostatic vertical distribution. I am seeking the right boundary condition for such a case.
Any hints warmly appreciated!
Tom
tomdylan is offline   Reply With Quote
Old   October 15, 2016, 17:22
Ruggero Poletto
Tom
No the third term is just a common thing in openfoam. It's the variable value on the surface (I.e. the displacement is zero at first iteration)
Old   October 16, 2016, 18:26
bigphil's Avatar
Philip Cardiff
Hi Tom,
To add to the previous comment, I noticed from the other thread that you are interested in poro-elasticity; you should be careful to not to confuse the pore-pressure with the "pressure" in the solidTraction boundary condition, which is the normal component of the effective traction (or total traction depending on your particular implementation).
Philip
Old   October 26, 2016, 12:49
Default time varying tractionBC in response to hydrostatic fluctuations
tomdylan's Avatar
Tom Dylan
Dear Foamers,
first, Philip, let me thank you again for your clarification on the difference between pore-pressure and pressure. to be honest I was at first sight a little bit confused but after a while I got things clear.
Allow me to present some pictures to illustrate the analysis I am into right now. I want to apply a representative (in respect to the water level in the chamber) tractionBC on a vertical (or inclined) soil boundary patch.
At the present I am not considering the rigid gravity wall structure of
the ship lock, since I have not managed to deal with heterogeneity/multiregions.
As you can figure out form the pictures the filling and emptying of the chamber (more the 6 m head difference)
leads to a time varying hydrostatic pressure distribution along the horizontal sole and the chamber walls. At the bottom the traction BC is straight forward. However I am insecure as to how to represent a time varying traction BC at the vertical (or inclined) boundary patches resulting form a fluctuating hydrostatic pressure in the chamber.
Interestingly, our groundwater measurements in a distance from the lock detected a clear and almost in-phase poroelastic response to the filling and emptying of the chamber in a range of up to 10 kN/m2 (yes the ground can react quite elastic). These head fluctuations are solely induced by stress variations in the chamber.
I guess that I am not the first to deal with head fluctuations and their effect on solid traction and therefore suppose that a solution exists, but currently I have no clue for this kind of problem.
Ana hints warmly appreciated!
Tom
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 05:43
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 19:57
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
