BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure
Old   March 6, 2016, 10:48
Default BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure
vinguva's Avatar
vinguva is on a distinguished road
Hello FOAMers
Here is a link of the Project before I discuss what is going on: https://drive.google.com/open?id=0Bz...TV4WXdpR3BJOEE
My aim is to simulate a Wind Turbine in large channel via an actuator disk. The goal is to have a high pressure region before the disk and a low pressure after the disk indicating power has been removed from the flow. The flow velocity across the disk should flow from the high pressure region before the disk to the low pressure region after the disk.
Looking at the fan BC results, it seems that the velocity goes from low pressure to high pressure. I looked at other BCs like fanPressure and fixedJump, and all these three BCs have flow velocity from low pressure to high pressure.
My question is, is there a BC that exists to do what I want (i.e flow velocity from high pressure to low pressure)? I'm using OpenFoam 3.0.1 with Foam-Extend 3.2 currently compiling on another system.
Best Regards
vinguva
vinguva is offline   Reply With Quote
Old   March 6, 2016, 14:41
vinguva's Avatar
I also would like to ask another question with a problem I'm having with fanPressure, its throwing velocity out from both patches when it should be going in one and coming out the other.
Here is the case: https://drive.google.com/file/d/0Bzs...ew?usp=sharing
Best Regards
vinguva
Old   March 8, 2016, 00:46
vinguva's Avatar
Hello FOAMers,
The fan BC seems to work on OpenFOAM 2.2.x by simply setting: jumptable polynomial 2((0 0)(-1 10))
This however doesn't work on OpenFOAM 3.0.1 for whatever reason. Maybe someone who cares about the code should look into this.
Best Regards
vinguva
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
How can it b possible? Flow from low p to high p?? Chris FLUENT 5 January 28, 2003 07:29
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
