March 5, 2016, 15:44 |
rhoSimpleFoam, convergence to zero flow
Peter S.
I am entirely new to this forum and relatively new to OpenFoam. I adress this forum, because I am completely stuck. I am trying to simulate air flow through a nozzle with rhoSimpleFoam. Geometry was made with Salome, (background)meshed with blockMesh, refined with snappyHexmesh. the mesh looks good; checkMesh confirms this. I used all files for 0, constant and system from the rhoSimpleFoam tutorial angled duct (of course I changed blockMeshDict and snappyHexMeshDict) and put the nozzle-geometry in triSurface (in constant). After some changes the simulation converges but strangely enough it converges to zero flow. This is strange because in the 0/U file for the inlet-patch, I used flowRateInletVelocity and massFlowRate of 0.029 kg/s. I already tried replacing the nozzle-geometry with a simple straight pipe geometry, use identical files in 0, constant and system (except geometry-files). the simulation converges to a flow of zero !!! I am struggling with this issue for more than a month now and am probably getting blind for the real cause. can anyone help me ? I can share any file required. Thanks and best regards, Peter |
March 6, 2016, 06:18 |
files for this case
Peter S.
dear all,
To enable people to offer any help, below I post the files in 0, and the files fvSchemes and fvSolutions from system. looking forward to any help. Peter. alphat: dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { wall { type compressible::alphatWallFunction; Prt 0.85; value uniform 0; } inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } } epsilon: dimensions [0 2 -3 0 0 0 0]; internalField uniform 200; boundaryField { wall { type epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 200; } inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.005; value uniform 200; } outlet { type inletOutlet; inletValue uniform 200; value uniform 200; } } k: kInlet 1; dimensions [0 2 -2 0 0 0 0]; internalField uniform $kInlet; boundaryField { inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.05; value uniform $kInlet; } outlet { type inletOutlet; inletValue uniform $kInlet; value uniform $kInlet; } wall { type kqRWallFunction; value uniform $kInlet; } } nut: dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } wall { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } } p: pOut 110000; dimensions [1 -1 -2 0 0 0 0];// internalField uniform $pOut; boundaryField { inlet { type zeroGradient; refValue uniform $pOut; refGradient uniform 0; valueFraction uniform 0.3; } outlet { type fixedValue; value uniform $pOut; } wall { type zeroGradient; } } T: Tinlet 413; dimensions [0 0 0 1 0 0 0]; internalField uniform $Tinlet; boundaryField { wall { type zeroGradient; } inlet { type fixedValue; value uniform $Tinlet; } outlet { type inletOutlet; value uniform 413; inletValue uniform 413; } } U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type flowRateInletVelocity; massFlowRate constant 0.029; rhoInlet 1.1; } outlet { type inletOutlet; value uniform (0 0 0); inletValue uniform (0 0 0); } wall { type fixedValue; value uniform (0 0 0); } fvSchemes: } dtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phid,p) bounded Gauss upwind; div(phi,Ekp) bounded Gauss upwind; div((phi|interpolate(rho)),p) Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; fvSolution: solvers { p { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } "(U|e|k|epsilon)" { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin 0.1; rhoMax 1.0; transonic yes; consistent yes; pRefPoint (0.01 0.01 0.01); pRefValue 0; residualControl { p 1e-3; U 1e-4; e 1e-3; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 1; rho 1; } equations { p 1; U 0.9; e 0.9; k 0.9; epsilon 0.9; } } |
rhosimplefoam |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
momentum & x-vel convergence, and reverse flow problem | cinwendy | FLUENT | 0 | April 17, 2013 03:19 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 05:55 |
Convergence but incorrect results in Free Surface flow | fmjb | CFX | 10 | October 26, 2011 08:18 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
