OpenFOAM parallel on multiple nodes
Old   March 4, 2016, 17:16
Default OpenFOAM parallel on multiple nodes
Ferdinand Pfender
FerdiFuchs is on a distinguished road
Hi everyone,
im trying to get OpenFOAM to work in parallel on 2 nodes (each wich 16 cores).
for example, when i run foamjob -p -s simpleFoam, everything starts.
No error occurs, and on both machines the solver starts with 16 processes (listed in top).
this situation is not changing, while the output of foamjob is stuck:
Parallel processing using OPENMPI with 32 processors
Executing: /programme/OpenFOAM/OpenFOAM-3.0.x/ThirdParty-3.0.x/platforms/linux64Gcc/openmpi-1.10.1/bin/mpirun -np 32 -hostfile machines -x FOAM_SETTINGS /programme/OpenFOAM/OpenFOAM-3.0.x/bin/foamExec -prefix /programme/OpenFOAM simpleFoam -parallel | tee  log
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x-ebc9d688cb1a
Exec   : simpleFoam -parallel
Date   : Mar 04 2016
Time   : 22:10:38
Host   : "secret_host_1"
PID    : 14357
Does somebody has an idea whats wrong or what i've missed??
by the way, im using zsh and tmux, may this be a problem? i also tried it with a blank bash session; still the same...
Thanks in purpose!
FerdiFuchs
FerdiFuchs is offline   Reply With Quote
Old   March 4, 2016, 18:36
Ferdinand Pfender
solved it with brunos help:
http://www.cfd-online.com/Forums/ope...tml#post378633
thanks!
MPI code on multiple nodes, scalability and best practice t.teschner Hardware 0 October 7, 2014 06:07
Issue with OpenMPI-1.5.3 while running parallel jobs on multiple nodes LargeEddy OpenFOAM 1 March 7, 2012 18:05
Running in parallel on multiple nodes kalyangoparaju OpenFOAM 5 January 18, 2012 12:36
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
