March 1, 2016, 14:32 |
FOAM FATAL ERROR for Different dimensions
Rupesh
Rep Power: 10 |
Hello Foamers,
I am unable to understand the following error related to Different Dimensions. I am using "sonicDymFoam" as my solver , and my dimensions for p and U are p =[1 -1 -2 0 0 0 0] U=[0 1 -1 0 0 0 0] "Selected 0 cells for refinement out of 57432. Selected 0 split points out of a possible 0. solidBodyMotionFunctions::linearMotion::transforma tion(): Time = 0.0001 transformation: ((0 0.0001 0) (1 (0 0 0))) --> FOAM FATAL ERROR: Different dimensions for -= dimensions : [1 0 -1 0 0 0 0] = [0 3 -1 0 0 0 0] From function dimensionSet:perator-=(const dimensionSet&) const in file dimensionSet/dimensionSet.C at line 199. FOAM aborting" Please let me know if more information is needed from my end to better understand this error. Thanks in advance !! |
April 10, 2016, 18:23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I don't know if you've solved this issue or not, but please follow the steps given here: http://www.cfd-online.com/Forums/ope...-get-help.html
And please keep in mind that if you need people to stop and ask you for more details, that also takes time, time which could have been spent answering your question For example, I will unlikely be able to look into your case in the next few weeks, given that you didn't provide enough details here |
April 27, 2016, 05:14 |
Rupesh
Rep Power: 10 |
Dear Bruno,
Many thanks for sharing the info. I have posted my query/error in other thread on dynamicTopoFvMesh. Regards, Rupesh |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 05:14 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
