Diverging Temperature in LES - which settings to adjust? |
February 23, 2016, 23:14 |
Rep Power: 11 |
I'm running LES of a turbulent jet using ~1.6 million cells and a Courant Number of 0.3. My solver is customized, but all of the non-standard features are turned off and it should be behaving identically to reactingFoam with all reactions turned off. At some point, an instability arises: at first, I get a few warnings that T is outside of the allowable range (300-5000 K) - say 5100 K - but then these warnings get more frequent and more problematic, until there are thousands at each time step and the associated temperatures range from -1e16 to +1e16.
My best guess for what's going on is that I've failed to appropriately model the pressure-momentum coupling, and that I need to add more pimple loops - is this the correct fix? I have seen an article [https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM] which suggests, among other things:
My question: What settings should I be changing to avoid this instability? For reference: The output of checkMesh: Code:
Mesh stats points: 1617892 faces: 4824873 internal faces: 4797927 cells: 1603800 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 1603800 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology JET 405 424 ok (non-closed singly connected) PILOT 864 900 ok (non-closed singly connected) COFLOW 1404 1440 ok (non-closed singly connected) OUTERRADIUS 21600 21636 ok (non-closed singly connected) OUTLET 2673 2692 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.07172601826 -0.07172601826 0) (0.07172601826 0.07172601826 0.36) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.5360889850782e-16 2.502408869494276e-16 3.295433281148142e-16) OK. Max cell openness = 4.165398281849697e-16 OK. Max aspect ratio = 22.5683629471026 OK. Minimum face area = 5.055728864375342e-08. Maximum face area = 3.708057695313814e-05. Face area magnitudes OK. Min volume = 1.872805105800212e-11. Max volume = 4.104974063197774e-08. Total volume = 0.003402726340535457. Cell volumes OK. Mesh non-orthogonality Max: 22.23980401213051 average: 2.729797707905458 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.5165905340833714 OK. Coupled point location match (average 0) OK. Mesh OK. Code:
ddtSchemes { default backward; } gradSchemes { default Gauss linear; } divSchemes { div(phi,rho) Gauss limitedLinear phi 1; default Gauss limitedLinear 1; div(phi,U) Gauss limitedLinearV 1; div(phi,Yi_h) Gauss multivariateSelection { CO2 limitedLinear01 1; H2O limitedLinear01 1; NO limitedLinear01 1; N2 limitedLinear01 1; h limitedLinear 1; }; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } Code:
"(p|rho)Final" { $p; relTol 0; } "(U|h|Z|varZ|Yi|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.01; } "(U|h|Z|varZ|Yi|k|epsilon)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 2; nCorrectors 3; nNonOrthogonalCorrectors 2; turbOnFinalIterOnly false; } relaxationFactors { fields { } equations { ".*" 1; } } |
March 7, 2016, 15:32 |
Rep Power: 11 |
I believe I found the problem. I had a turbulentInlet BC and the magnitude of the fluctuations was far too large - presumably this caused this instability. For reference, a fluctuationScale of 0.1 or larger is very big.
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Ansys Structural Environmental Temperature | zytra | Structural Mechanics | 0 | October 31, 2014 15:32 |
How to adjust wall temperature | nutow | FLUENT | 0 | September 4, 2011 06:37 |
[swak4Foam] adjust inlet temperature depending on values of monitor points (groovyBC) | braennstroem | OpenFOAM Community Contributions | 2 | May 31, 2011 14:45 |
adjust gradient temperature on the cylinder's wall | Konrad | FLUENT | 1 | August 28, 2006 08:16 |
