Mutliphase flow: division by zero in incompressible turbulence model |
February 23, 2016, 10:21 |
Gautham varma
Rep Power: 10 |
This is one of the first time i am using openfoam multiphase flow. I have a tank with oil upto a level and i wanted to simulate a flow of air from inlet to outlet. I am using dambreak ran interfoam solver as a base and working from there. However, for some reason i cant get a solution as the Openfoam solver gives me fatal error and exiting . this is the error that i obtain Foam::error:: PrintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::RASModels::kEpsilon<Foam::IncompressibleTurb ulenceModel<Foam::transportModel> >::correct() at ??:? #6 ? at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? at ??:? Floating point exception (core dumped) I cant solve this problem at all so can somebody give me some guidelines? thanks Last edited by Gautham91; February 23, 2016 at 10:26. Reason: inlcuding the error file |
February 23, 2016, 13:25 |
Saideep
Rep Power: 12 |
guess you changed the solver and at some point you are dividing a variable with 0 {floating point error}. Saideep |
February 24, 2016, 03:32 |
#3 | |
Mohammad Shakil Ahmmed
Rep Power: 15 |
Cheers, Shakil |
February 25, 2016, 09:28 |
Gautham varma
Rep Power: 10 |
Thank you guys.
interfoam, openfoam 2.0.x |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
turbulence model for Refrigerator | cicatrix | Main CFD Forum | 0 | October 3, 2012 02:47 |
Turbulence model for Laminar flow | Terry | Main CFD Forum | 8 | August 14, 2010 06:45 |
Turbulence Model for Transient Incompressible flow | astro1 | Main CFD Forum | 5 | May 5, 2007 12:07 |
