problem OpenFOAM version incompatibility: going from 1.7.1 to 3.0.1 |
February 23, 2016, 07:30 |
lynda
Rep Power: 17 |
Hi !
I was working on the Version OF1.7.1 under interFoam application, the problem when I installed the new version OF3.1, my example was walking on the old version no longer works on the new version, if you please help me? |
February 23, 2016, 11:55 |
Joćo Ferreira
Rep Power: 12 |
it is normal to have problems when you change the openfoam's version, a lot of things change from version to version. Anyway, despite that, without more information it's imposible to help you out. Usually the error printed on terminal contains a lot of information to solve the problem. Perhaps post it here. |
March 1, 2016, 07:55 |
lynda
Rep Power: 17 |
Hi
this is error printed on my terminal interFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-d8a290b55d28 Exec : interFoam Date : Mar 01 2016 Time : 12:50:44 Host : "Luke" PID : 6889 Case : /home/boubendir/OpenFOAM/boubendir-3.0.1/run/tutorials/multiphase/interFoam/laminar/lynda/ug40 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'object' on line 14 and ending at line 73950" file: /home/boubendir/OpenFOAM/boubendir-3.0.1/run/tutorials/multiphase/interFoam/laminar/lynda/ug40/0/alpha.water at line 73950. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting thank you |
March 1, 2016, 11:57 |
Rep Power: 12 |
Look up the interFoam tutorials in the newer OF version and check where your files are different. fvSchemes, fvSolution, transportProperties, controlDict, etc. It is normal that the syntax is changing between versions.
Maybe some boundary condition has been replaced or renamed. |
March 2, 2016, 03:49 |
Joćo Ferreira
Rep Power: 12 |
from the error printed it appears that on the "alpha.water" file, at the /0 folder, there's no 'object' entry on the line 14. Check the file, right under the header, it should look like this: Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 05:36 |
OpenFOAM 1.7.1 installation problem on Fedora 14 | armonica | OpenFOAM Installation | 16 | March 31, 2011 14:16 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
