Tutorial/functional case for solidificationMeltingSource |
May 28, 2018, 13:49 |
#21 | |
Tarang
Rep Power: 15 |
this fvoption uses sms1:alpha1, ie ':', colon in filename. If you are using openfoam in windows, then the file may not be written as windows does not allow ':' in filenames |
April 9, 2019, 11:36 |
#22 | |
Anna
Rep Power: 7 |
Hi there,
I'm trying to get sms1:alpha1 variable for using it as a condition of a new variable in chtMultiRegionFoam but I'm having problems getting the variable because it doesn't recognize it: Quote:
Thanks! |
April 9, 2019, 12:40 |
#23 |
Tarang
Rep Power: 15 |
The variable alpha1_ will not be found directly as you are using. It is there in the memory but not in the .C or .H file in which you are calling.
First you have to search for the variable and then load it. Here you can go ahead in this direction: Code:
volScalarField liquidFraction = this->mesh_.objectRegistry::lookupObject<volScalarField> ("sMS1:alpha1"); You may have to tweak the above code a bit to match the variable names present in the file. You may also look at the documentation of chtmultiregionfoam on cpp.openfoam.org. -gtarang |
April 10, 2019, 05:33 |
#24 | |
Anna
Rep Power: 7 |
Thank you very much!
I've fixed the problem changing a little bit your function: Quote:
May 26, 2021, 03:42 |
liquid fraction update
#25 | |
Rep Power: 6 |
I have asked that same question too, seems like you are a mile ahead of me in PCM. I have seen your code too, where you remove the snippet above? May I ask, how was your result? Is there any change? It seems like mine is blowing up.. Thanks.. Last edited by mikulo; May 26, 2021 at 07:39. |
June 4, 2021, 02:38 |
#26 |
Tarang
Rep Power: 15 |
I didn't remove that code. That code ensures that liquid fraction is updated only once in a timestep.
-Tarang |
June 4, 2021, 06:55 |
#27 |
Rep Power: 6 |
Hello Tarang,
Yes, I understand you. However, if it is updated only once, then the liquid fraction is not corrected, right?Thus, I removed it and make some changes a little bit at the top level. |
November 18, 2023, 15:21 |
#28 |
Akshay Ghorpade
Hi Anna
In solidificationandMelting Source files (.C and .H) I am unable to understand the placement of this piece of code. const volScalarField& liquidFraction = mesh.lookupObject<volScalarField>("sMS1:alpha1"); Last edited by Akshay_Ghorpade; November 18, 2023 at 15:25. Reason: Didn't write the complete information |
April 11, 2024, 08:19 |
chtMultiRegionFoam with solidificationMeltingSource
#29 |
Kevin Redosado
Rep Power: 4 |
Hi, I can run the case with bouyantFoam but when I try to use chtMultiRegionFoam the fvOptions "solidificationMeltingSource" does not work. Does anyone know why?
April 11, 2024, 21:41 |
#30 |
Rep Power: 6 |
May 16, 2024, 10:51 |
#31 | |
Kevin Redosado
Rep Power: 4 |
[/QUOTE]
I cannot upload my case because it says security token is missing btw. And thanks in advance. |
June 13, 2024, 01:57 |
#32 |
Carlos Alarcon
Rep Power: 5 |
Hi, I attached working melting gallium example running in openfoam11. In case someone needs to not work with a version from 15 years ago.
Launch like this $ blockMesh $ decomposePar $ mpirun -np 8 foamRun -parallel > log & $ reconstructPar $ paraFoam |
September 6, 2024, 17:31 |
SolidificationMelting with Shrinkage void
#33 | |
JANGA RAKESH KUMAR
Rep Power: 2 |
Hello Foamers I want to capture the shrinkage void at air and solid(liquid) interface during solidification. Does anybody know how to couple interFoam with this solidification solver???? If anybody has solver for this type of case, please share here Or else, If anyone knows how to make this solver, please explain. Currently, I'm struggling to setup my testcase for my thesis for this type of 3 phase. Any sort of help regarding this problem is greatly appreciated. Thanks in advance. -Rakesh |
October 28, 2024, 09:58 |
#34 |
Rep Power: 17 |
Hi foamers,
I tried to run the attached example in openfoam-2312 but I got negative temperature with foam aborting. I just added Code:
pRefCell 0; pRefValue 0.0; Any idea of what's wrong here? Thank you, Nando |
melting, phase change |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 11:13 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 12:20 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 11:25 |
