problem w/ running simpleFoam in parallel
Old   February 16, 2016, 17:17
MAZI
mazdak is on a distinguished road
that's great. decomposing is performed. but, still does not run the simplefoam case
mazdak is offline   Reply With Quote
Old   February 16, 2016, 17:19
MAZI
the decomposing is performed greatly, but simpleFoam does not run
/share/apps/OpenFOAM/OpenFOAM-2.4.0/bin/tools/RunFunctions: line 75: mpirun: command not found
Old   February 16, 2016, 17:22
MAZI
the decomposing is performed with no problem, but simpleFoam can't be run:
Old   February 16, 2016, 17:37
MAZI
there should be a problem with the versions. I have both 2.4.0 and 3.0.0 versions
Old   February 16, 2016, 17:58
Kaufman
kmefun is on a distinguished road
I implement your testCase and there is no error showing.
Are you using HPC to compute your testCase? If so, please check there is no error in your script.
like your testCase is setup for OF 3.0.0
However, you use "source /share/apps/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc" in your runHOU.sh
kmefun is offline   Reply With Quote
Old   February 16, 2016, 18:03
MAZI
thank you so much man. It really helped. hope we can communicate more. Really appreciate it
Old   December 8, 2023, 04:07
yingting tang
tyting is on a distinguished road
Hi,all.I got a problem:
I run the "decomposePar" and generate some processor0/1/../9 file,but when I run my solver "myinterFoam" in parallel,the problem occour:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] myinterFoam: cannot open case directory "/home/.../mysimulation/refinemesh_test/processor0"
[0]
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Does anyone know what happen and how can I solve it?
Thanks for any help!
tyting is offline   Reply With Quote
Old   December 8, 2023, 04:10
yingting tang
Originally Posted by mazdak View Post
I'm trying to run turbulent pipe flow using simpleFoam, but unfortunately, I get some errors. Please see below to find the errors. I also attach some files used for running the case in parallel. Any thought will be appreciated. Thanks
| \\ / O peration | Version: 3.0.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.0-6abec57f5449
Exec : simpleFoam -parallel
Date : Feb 16 2016
Time : 09:09:35
Host : "compute-0-1.local"
PID : 44738
Case : /home/mazdak/Ex3
nProcs : 4
Slaves :
3
"compute-0-1.local.44739"
"compute-0-1.local.44740"
"compute-0-1.local.44741"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
[0]
[0]
[0] simpleFoam: cannot open case directory "/home/mazdak/Ex3/processor0"
[0]
[0]
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
Hi,all.I got a similar problem:
[0]
[0]
[0]
[0]
[0]
with errorcode 1.
OF 2.0.1 parallel running problems moser_r OpenFOAM Running, Solving & CFD 9 July 27, 2022 04:15
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 07:53
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 06:06
parallel mode - small problem? co2 FLUENT 2 June 2, 2004 00:47
