My question is as simple as it appears. Whenever I use zero mass in my 6DOF simulations, the solver (namely pimpleDyMFoam) blows up at the start of the process with Floating point exception. However zero mass in a sixDOF problem isn't impossible. Here is my DynamicMeshDict: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libsixDoFRigidBodyMotion.so"); solver sixDoFRigidBodyMotion; sixDoFRigidBodyMotionCoeffs { patches (cylinder); innerDistance 1; outerDistance 20; mass 0; momentOfInertia (0.01 0.01 0.01); centreOfMass (0 0 0); orientation ( 1 0 0 0 1 0 0 0 1 ); velocity (0 0 0); acceleration (0 0 0); angularMomentum (0 0 0); torque (0 0 0); g (0 0 0); rhoName rhoInf; rhoInf 1; report on; accelerationRelaxation 0.3; value uniform (0 0 0); solver { type symplectic; } constraints { transverse { sixDoFRigidBodyMotionConstraint line; tolerance 1e-6; relaxationFactor 0.7; refPoint (0 0 0); direction (0 1 0); } noRotation { sixDoFRigidBodyMotionConstraint orientation; orientation (1 0 0 0 1 0 0 0 1); } zAxis { sixDoFRigidBodyMotionConstraint axis; axis (0 0 1); } } restraints { translationSpring&Damper { sixDoFRigidBodyMotionRestraint linearSpring; anchor (0 -10 0); refAttachmentPt (0 0 0); stiffness 0; damping 0; restLength 10; } } } Code:
void Foam::::updateAcceleration ( const vector& fGlobal, const vector& tauGlobal ) { static bool first = false; // Save the previous iteration accelerations for relaxation vector aPrevIter = a(); vector tauPrevIter = tau(); // Calculate new accelerations a() = fGlobal/mass_; tau() = (Q().T() & tauGlobal); applyRestraints(); // Relax accelerations on all but first iteration if (!first) { a() = aRelax_*a() + (1 - aRelax_)*aPrevIter; tau() = aRelax_*tau() + (1 - aRelax_)*tauPrevIter; } first = false; } Any Ideas how I can solve a 6DOF problem with zero mass?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
#2 | |
The only workaround I have found so far is to set very low amounts of mass and accelerationRelaxation:
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" Last edited by Mojtaba.a; February 14, 2016 at 13:33. |
6dof, sixdofrigidbodymotion, zero mass |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 05:55 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
