Temperature dependent density in transportProperties when using polynomials
Old   February 11, 2016, 06:29
Default Temperature dependent density in transportProperties when using polynomials
Gregor Alan
GregorAlan is on a distinguished road
Hi all,
I am trying to use a temperature dependent ideal gas law for the density in the chtMultiRegionSimpleFoam solver. The reason why I can't use the normal ideal gas law option is because I have a polynomial equation for mu, thermal conductivity as well as Cp. I either have to use PengRobinsonGas or give a polynomial for the temperature dependent density (assuming constant pressure). Is there a way to have a negative power in this polynomial to effectively reconstruct the ideal gas law but then define it in the thermophysicalProperties?
Kind regards,
Gregor Alan
GregorAlan is offline   Reply With Quote
OpenFOAM solver for incompressible BUT temperature dependent flow niko0807 OpenFOAM Running, Solving & CFD 2 October 27, 2015 06:31
Density of fluid with respect to temperature and pressure akash_max CFX 4 November 6, 2011 10:00
Density as a function of Pressure and Temperature yenyeskumar CFX 0 November 4, 2011 03:17
UDF: temperature dependent BC ehooi FLUENT 6 January 22, 2011 13:26
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 02:22
